3.1.x Extensions Database 3.1 / 3.2Link bbCode Extension
Banned
Banned
Re: Link bbCode Extension
OK
I don't see the BBCode with Advanced BBCode Box
There is your issue Advanced BBCode ext your trying to use two templates.
Banned
Banned
I just tried by disabling Advanced BBCode Box, it doesn't work just by enabling the extension
Sure it does see here.
dmzx-web.net
Banned
Banned
Oops! my fault!!
I did not fill in this Download-link before the URL
And the extension works with Advanced BBCode Box
Thanks U
EDIT
To integrate the Download-link menu into the Advanced BBCode Box, you must modify the abbc3_posting_buttons.html template in /ext/vse/abbc3/styles/all/template
ssl wrote: 03 Oct 2020, 14:43OK thanks, i try
maybe you put the example/text wrong
Banned
Banned
So you can read this > Link bbCode Extension, problem solved
Fast_Eddie
Post by Fast_Eddie »
I would very much like to use this ext. on my 3.3.2 board ,....it installed ok but did not include the download link box . I do have in my custom bbcode box but it's not parsing the url for d/l correctly. Would it need to be updated to run on 3.3x or did i do something wrong?
:beers: Retirement 2024!
Banned
Banned
Use it on phpBB 3.3.2 without trouble.
Fast_Eddie
It might not work for what I'm trying to do then (Did notice DM is using it here also)
Am trying to use the file upload ext for mp4 (video) server.
User uploads mp4 file and gets the url for it. And then embeds the url in a post (( Everything in this part works great ))
But i also want to include a way to d/l it. Right now it only plays with no d/l link
Banned
Banned
Perhaps try this extension: Downloadlog
Fast_Eddie
Ok here is what I have using phpbb 3.3.2
It installs ok but after that nothing works
Test Board
It got the drop down menu ok ...but won't process the link
Comes out like this:
Same result on live board but no drop down menu appears
Banned
Banned
So I'll repeat what I told you here.
This extension is not intended for downloading files, it is just a BBCode which directs you to a download site. To do what you want, you have to use Downloadlog
Fast_Eddie
This extension will add a download link selection box in posting template.
:question:
Fast_Eddie
    Windows 7 Edge
ssl wrote: 25 Dec 2020, 20:06 So I'll repeat what I told you here.
All this ext does is log who down loaded what
I need a ext (or BBcode) that gives a user the ability to download a file outside the attachment system that's built into phpbb
Which THIS extension is supposed to do. :wall: :wall: :wall:
