Extensions Database 3.2 / 3.3 / 4.0 ⇒ 3.3 & 4.0 Contact Page Captcha
3.2 & 3.3 & 4.0
19 given 2
Extension Name: Contact Page Captcha
Adds a guest-only captcha to the Contact a Board Administrator page, using phpBB events only.
- Rebuilt on phpBB events: `core.message_admin_form_submit_before` validates the captcha, the `memberlist_email_before` template event renders it. No more core-file edits, dmzx/editor is no longer needed.
- Works on phpBB 3.3 and 4.0, with every captcha plugin (tested with Turnstile on 4.0 and GD on 3.3).
- Upgrading from 1.x: disable, Delete Data, remove the old folder, then install 2.0.0 (README).
  2. Unzip the downloaded release, and change the name of the folder to `contactpagecaptcha`.
  4. Copy the `contactpagecaptcha` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/contactpagecaptcha/composer.json
  6. Look for `Contact Page Captcha` under the Disabled Extensions list, and click its `Enable` link.
