Extension name: Max-width switch
Author: Crizzo
Extension description: This extension adds the ability to the UCP to remove the max-width of prosilver.
Github: https://github.com/Crizz0/phpbb-ext-maxwidth-switch
Extension version: 1.1.0
Download file: crizzo_maxwidthswitch_v1_1_0.zip
File size: 15.71 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2548876&p=15480571#p15480571
Extension official releases ⇒ phpbb [3.3.x] Extensions Database Releases • Max-width switch
- Dmzx-web.net
