3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Youtube Videos Gallery
Prosk8er
Re: Youtube Videos Gallery
Weird works with that api key are your settings the same as mine
Who knows lol feel free to use that api.
Prosk8er
Ok got it working with my own api key
i enabled the YouTube Data API v3 and restricted the key to it
Thanks for your feedbackProsk8er wrote: 16 Feb 2023, 13:07 ok got it working with my own api key
Prosk8er
Yup no problem
i told mrix2000 on phpbb about it and his is back working again also
for anyone one else with the issue heres the fix
go to https://console.cloud.google.com/apis/credentials
click library on the left menu
search for youtube
click YouTube Data API v3
click enable
click credentials in left menu
click your api key
click restrict button and restict to the enabled YouTube Data API v3
than click save
search for youtube
click enable
click your api key
than click save
Anuj Dhawan
It seems like anyone can post a video or is there a control using member type? Like only moderators can post a video? Please advise.
Join us: http://www.zMainframes.com/
Anuj Dhawan
I know pestering does not take you anywhere, however, I seek a guidance on this.Anuj Dhawan wrote: 16 Jul 2023, 19:24 It seems like anyone can post a video or is there a control using member type? Like only moderators can post a video? Please advise.
Appreciate your time,
- Donator
In ACP/Users and Groups/group permissionAnuj Dhawan wrote: 27 Dec 2023, 18:30I know pestering does not take you anywhere, however, I seek a guidance on this.Anuj Dhawan wrote: 16 Jul 2023, 19:24 It seems like anyone can post a video or is there a control using member type? Like only moderators can post a video? Please advise.
Anuj Dhawan
Thanks, this helps.
I'm not sure if it's only me - but the replies on videos does not seem to generate the notification neither it adds to the post count of the user. Is this an intended behavior?
- Donator
By notification you mean an alert, reminder or popup saying someone replied to one of your videos?Anuj Dhawan wrote: 28 Dec 2023, 14:42 Thanks, this helps.
If so I don't think it has that option, not that I know of...
Anuj Dhawan
Yes, this is what I meant.clight77 wrote: 29 Dec 2023, 01:40 ... or popup saying someone replied to one of your videos?
- Donator
Like I said, there is no notification setting. :)Anuj Dhawan wrote: 31 Dec 2023, 07:58Yes, this is what I meant.clight77 wrote: 29 Dec 2023, 01:40 ... or popup saying someone replied to one of your videos?
Anuj Dhawan
I think having one would help in more participation from members. Thanks for your help though, clight77.
panhead
The videos on the index page are round, in the examples in the first post they are square. How can I make them square?
