3.1.x Extensions Database 3.1 / 3.2Top Stats
Re: Top Stats
Link to the theme your using and il post the fix for you.
Fast_Eddie
Re: Top Stats
Post by Fast_Eddie »
Here ya go Martin, and thank you :)
https://www.phpbb.com/community/viewtop ... &t=2367666
:beers: Retirement 2024!
Re: Top Stats
open ext/dmzx/topstats/styles/prosilver/template/event/overall_footer_after.html
replace the code in that file with this
<!-- IF (S_TSRAT_ENABLE and S_TS_JSSCROLL) or (S_TSRAT_ENABLE and S_TS_TICKER) -->
<!-- IF S_TS_JSSCROLL and not S_TS_TICKER -->
<!-- INCLUDEJS jquery.totemticker.min.js -->
// ]]><![CDATA[<![CDATA[
$(document).ready(function() {
	$('#vertical-ticker').totemticker({
				row_height	:	'58px',
				max_items	:	3,
				speed		:	{JSSCROLL_SPEED},
				interval	:	{JSSCROLL_INTERVAL},
				<!-- IF TS_JSSCROLL_NAVIGATION -->
				next		:	'#ticker-next',
				previous	:	'#ticker-previous',
				stop		:	'#stop',
				start		:	'#start',
				mousestop	:	true,
				direction	:	'<!-- IF TS_JSSCROLL_DIRECTION -->down<!-- ELSE -->up<!-- ENDIF -->'
// ]]>]]><![CDATA[
</script>
<!-- ELSEIF S_TS_TICKER and not S_TS_JSSCROLL -->
<!-- INCLUDEJS jquery.newsticker.js -->
	$("#news").newsTicker();
// ]]>]]><![CDATA[
</script>
Fast_Eddie
Re: Top Stats
Thank you Martin,
But it had no effect. Purged and refreshed browser just to be safe. and no change
Edit: I'll try it on the test board and see what happens
Tried same thing on test board. No effect :(
Still 2 active topics instead of 3
Another Edit:
Just for grins I activated the list of last resisted members to logon, and now the j-scroll is working fine :D
Re: Top Stats
As you can see by the image it has 3 rows
the only change needed is this row_height : '58px',
There is a good chance its cached into your browser.
talonos
Re: Top Stats
Post by talonos »
martin wrote: 04 May 2016, 23:01 As you can see by the image it has 3 rows
isn't that the line used to set out the height of the rows THEN there is a css rule which is your above setting X3 to make it show 3 rows.
58px X 3 = 174
so in the CSS file for extension i think you have something like
ticker{
   position:relative;
   height: 123px;
   overflow: hidden;
so the height measurement in the block above would need to be
height: 174px;
Board3 mods/extensions available/created by Talonos @ http://pretereo-stormrage.co.uk
Re: Top Stats
Correct but it fails so just change the row.
I posted a fix just for this on stokers site if i can find it il link to it.
niko
Re: Top Stats
Post by niko »
Sorry if I failed to find an solution for this but jquery scrolls etc does not work/show with Arty styles such as latte and digi which are common used styles. Is there any way I can make this work? Thank you
Edit: topic preview ext doesnt work with this as well.
Re: Top Stats
niko wrote: 06 Jun 2016, 04:04 Sorry if I failed to find an solution for this but jquery scrolls etc does not work/show with Arty styles such as latte and digi which are common used styles. Is there any way I can make this work? Thank you
Is there a js conflict? can you see?
rogerio24
    Linux Firefox
Re: Top Stats
Post by rogerio24 »
Has someone created the Spanish package for this extension?
Thanks!
raykai
Re: Top Stats
Post by raykai »
How can i get the collapse icon to work on this mod ? i have it for all my other forum section but not on this mod.
im on phpbb 3.1.9
Re: Top Stats
raykai
Re: Top Stats
Post by raykai »
martin wrote: 29 Jun 2016, 09:35 viewtopic.php?f=52&t=814
its giving You are not authorised to read this forum. :(
Gavo
Re: Top Stats
Post by Gavo »
Very nice mod. I made it display next to the chatbox.
I just noticed it doesn't update with new topics, is there anyway to make it update without refreshing the page?
Re: Top Stats
Yes add ajax to it but then your host will moan.
