3.3.x Extensions Database 3.2 / 3.3Topic Image
Salvo Cortesiano
Re: Topic Image
Post by Salvo Cortesiano »
I use the forumUS style
This style is not free, I paid for it. Any hope to adapt the extension to this style?
Best Regards
Salvo
Re: Topic Image
What extension needs to be adjusted?
Salvo Cortesiano
Re: Topic Image
dmzx wrote: 18 Jun 2024, 13:26 what extension needs to be adjusted?
the Topic Image extension.
Thanks for your reply
I'm sending you a PM, I need a favor :smile:
Regards
Salvo
phpbbexst
Re: Topic Image
Post by phpbbexst »
I would like guests to see the images, tried to edit the html file by removing the code of interest, but it gives me error, what should I do to achieve this.
phpbbexst
Re: Topic Image
Post by phpbbexst »
phpbbexst wrote: 22 Jul 2024, 19:31 I would like guests to see the images, tried to edit the html file by removing the code of interest, but it gives me error, what should I do to achieve this.
Open: /template/topicimage.html
Find:
{% if S_DMZX_TOPICIMAGE_ENABLE and S_USER_LOGGED_IN and not S_IS_BOT and dmzx_topicimage %}
replace with this:
{% if S_DMZX_TOPICIMAGE_ENABLE and not S_IS_BOT and dmzx_topicimage %}
Open: /template/event/overall_footer_after.html
Find:
{% if S_DMZX_TOPICIMAGE_ENABLE and S_USER_LOGGED_IN and dmzx_topicimage %}
replace with this:
{% if S_DMZX_TOPICIMAGE_ENABLE and dmzx_topicimage %}
Open: /template/event/overall_header_head_append.html
Find:
{% if S_DMZX_TOPICIMAGE_ENABLE and S_USER_LOGGED_IN %}
replace with this:
{% if S_DMZX_TOPICIMAGE_ENABLE %}
Re: Topic Image
Topic image grab no longer works could be alma linux 9 or even the new php version.
Re: Topic Image
martin wrote: 17 Feb 2025, 20:07 Topic image grab no longer works could be alma linux 9 or even the new php version.
does it give any error? log or acp?
Re: Topic Image
No images to grab standard message no errors.
foxtale
Re: Topic Image
Post by foxtale »
martin wrote: 18 Feb 2025, 13:31 No images to grab standard message no errors.
Same here :tumbsyes:
Needs update :wall:
Re: Topic Image
Update is being tested it has new options in.
Re: Topic Image
Re: Topic Image
medic
Re: Topic Image
Post by medic »
is there a way to show only images of the 20 first topics instead of random images
The Good
Re: Topic Image
Post by The Good »
Can we set last images not random image ?
Re: Topic Image
It selects the first image in a topic if i remember right.
