3.2 & 3.3 Extensions Database 3.2 / 3.3Custom Header Logo
TrekRed
Re: Custom Header Logo
Post by TrekRed »
Can this be fixed somehow?
Pingui
Post by Pingui »
Thx for all... :mml: :tumbsyes:
Be yourself, except if you're stupid, then it is better that you be another one.
I Amiga
- www.WinUAEspanol.com
I know, my english is very bad, sorry...
Pingui
Post by Pingui »
Hi again dmzx...
I am writing to you because when I have updated this extension I get the following error....
Note: Parse error: syntax error, unexpected ''FORUM_BACKGROUND'' (T_CONSTANT_ENCAPSED_STRING), expecting ')' in
/web/htdocs/www .winuaespanol.com/home/phpbb3/ext/dmzx/chl/language/es/acp_chl.php on line 44
I've looked at the translation I made and it's well done...
Spanish
44 'FORUM_BACKGROUND' => 'Fondo de la cabecera del foro',
English
44 'FORUM_BACKGROUND' => 'Forum header background',
Why do I get this error? I would appreciate your help...
Thank you very much.
Pingui
Post by Pingui »
Sorry for writing again...
I have already solved the problem and it was because at the end of some lines I didn't have the comma ",".
Greetings, and sorry for the double message...
The Good
Post by The Good »
Works fine for index forums topics..
but not for app.php/wallet app.php/contactadmin...
what I should to put in Page name: ??
thanks
Pingui
Post by Pingui »
Thx! for your fine work! :mml:
Pingui
Post by Pingui »
Hello again, dmzx :D
It's been a long time since I asked you about one of my stories :lol:
The first question I want to ask you is... I want to put a background in one of the sections of my forum, this image for example, is 20px x 20px in size, and what it does is fill in the whole gap in the header by stretching the image, not filling the gap with the image at its original size.
The other question I wanted to ask you... For example, we have a space in the header of 1125x120 px and I would like to put a background that is 1125x250 px. How can I automatically give the height size to the header without having to edit the corresponding php or css file? I'm saying this in case I want to change the image to another one with a different height.
I hope you can explain something to us.
Pingui wrote: 27 Mar 2025, 16:12 Hello again, dmzx :D
Can you post an image of the gap?
Pingui
    Windows 10 Edge
Post by Pingui »
Hi dmzx...
The first image I'm showing you is one of those I use to fill the header of some of the sections.
This is how I see it using Custom Header Logo 3.2.x (v1.0.2)
But if I update to Custom Header Logo (v1.0.5) the image changes completely, both the padding of the header and the height of the header.
Why does it do this if it worked perfectly in the previous version? That's why I asked you if there was any way to fill the header without distorting the image, as in the previous version.
And the other question was whether it would be possible to change the size of the header from the same extension, without having to touch up the style css.
As always, thank you very much for your help.
