3.2 & 3.3 Extensions Database 3.2 / 3.3Topic Index
Tarantino
Re: Topic Index
Post by Tarantino »
dmzx wrote: 20 Apr 2018, 09:44
eunaumtenhoid wrote: 17 Mar 2018, 02:36 Is it possible some addon?
as:
show the forum where the topic was posted
show extension qte (https://www.phpbb.com/community/viewtop ... &t=2218556)
topic descrition (https://www.phpbb.com/customise/db/exte ... scription/)
topic index of each user on profile? (showing all the topics of the user posted in that forum)
For now not, will check in next release what can be done.
+1
eunaumtenhoid
Re: Topic Index
Post by eunaumtenhoid »
More option:
option to edit list> name, forums
option to be able to show the group list, all or specific groups
add pagination (option in acp to determine the number of topicso in each page)
shows the link of each list in acp
eunaumtenhoid
Re: Topic Index
Is missing the paging, is overloading the server is possible to implement?
Peralta
Re: Topic Index
Post by Peralta »
Hi dmzx
Selecting the prefix filter generates a badly ordered list :sad:
I don't remember if this happened from the beginning when I installed it or was later from updating to successive phpBB updates...
Please, can you check?
Peralta
Re: Topic Index
Post by Peralta »
See:
Normal:
With prefix filter:
Re: Topic Index
Aforce
Re: Topic Index
Post by Aforce »
I've just come across this extension. I've been after something like this for a while. It will certainly help to avoid duplicate topics. :buigen:
eunaumtenhoid
Re: Topic Index
Was it add pagination?
Milunice259
Re: Topic Index
Post by Milunice259 »
Installed and it worked. Then disabled it and cannot re-enable it back. Is it an error?
ironside
Re: Topic Index
Post by ironside »
Thank you very much, I will test all of this :wink:
Image Proute To Be French :D
Re: Topic Index
English pls.
Tarantino
Re: Topic Index
Post by Tarantino »
Pagination would be great to have.
But I come about a problem. Characteres with accents as À or Á is going to # instead of going to A letter. The accents should be ignored.
Kudos
medic
Re: Topic Index
Post by medic »
Hi tx for this ext is there a french translation
thank you
stone23
Re: Topic Index
Post by stone23 »
medic wrote: 29 May 2021, 22:00 hi tx for this ext is there a french translation
you can find it here : https://www.phpbb.com/customise/db/exte ... 41#p809541
Re: Topic Index
