3.2.x Extensions Database 3.2 / 3.3Form Maker/Creator 3.2.x
Re: Form Maker/Creator 3.2.x
3.2.x
How hard would it be to add the Image bbcode tags to this ext as an element.
I tried and failed to do so.
Fast_Eddie
Post by Fast_Eddie »
Profile integration ?
Just askin :eyes2:
:beers: Retirement 2024!
Fast_Eddie wrote: 15 Aug 2017, 23:34 Profile integration ?
Just askin :eyes2:
Nope when using the form created you have to use an image from your PC and not a URL link like this: I have disabled the tags for this posting..
[img ]https://imagizer.imageshack.com/img924/4556/qmATdM.jpg[/img ]
Fast_Eddie
No prob, just wanted to put it out there :D
testing1
Post by testing1 »
I have installed this on 3.2.1 and am getting this message
any ideas or is it just not up to 3.2.1 yet?
This would be awesome to have working many uses for forms hope someone can get it working!
_________________________________________
This page isn’t working
mysite: is currently unable to handle this request.
HTTP ERROR 500
Funny
Post by Funny »
Under php 5.6 the form maker works perfectly
Under php7.0 etc., the extension unfortunately brings the HTTP 500 Error.
The extension should be updated
mg Funny
Pls read the first post it states 1.0.0-dev-a1 DEV being the main part to note.
testing1
Re: Form Maker/Creator 3.2.x - enguragment!
Post by testing1 »
martin wrote: 11 Sep 2017, 02:15 Pls read the first post it states 1.0.0-dev-a1 DEV being the main part to note.
Yes but we can still try and encourage NO?
marnux
Post by marnux »
just encountered an issue while trying to enable the extension on phpbb 3.2.1. It is working perfectly on phpbb 3.2, so i'm a bit confused. Unfortunately i'm no phpbb expert, nor have a lot of php knowledge to fix this.
Catchable fatal error: Argument 1 passed to phpbb\db\migrator::get_callable_from_step() must be of the type array, null given, called in phpBB3/phpbb/db/migrator.php on line 701 and defined in phpBB3/phpbb/db/migrator.php on line 723
I don't see a difference between the migrator.php of 3.2 and 3.2.1. Is there anyone which has a similar issue that was able to solve it?
EDIT: Bin reading through the migration documentation and can't find something that would be off.
marnux
Post by marnux »
Decided upon reinstalling phpbb 3.2.1 and now it enabled without obvious issue. The configuration module is not visible however in the extensions tab.
marnux
Post by marnux »
Got access to configuration after i was upgraded to founder/admin. Could it be that the permissions are a little different between 3.2 and 3.2.1?
eunaumtenhoid
Post by eunaumtenhoid »
How customization template post (bbcodes)?
Funny
Post by Funny »
The Form Maker does not work under php 7.xx.
Please upgrade it.
every other post here is just for free.
ZaneMcK
Post by ZaneMcK »
I second this. Please upgrade this extension to php 7.
I get that it is still in alpha state, but it's been almost a year now.
