Partner Page
Post Reply
mastnacek
Re: Partner Page
Post by mastnacek »
Great, big thanks man :tumbsyes: :beers:
miri4ever
Re: Partner Page
Post by miri4ever »
I got errors if disable and wanted to clear cache. It tell me some modules cant be removed from database
CANNOT_REMOVE_MODULE
phpbb/db/migration/tool/module.php(425): phpbb\module\module_manager->delete_module(748, 'acp') #1
phpbb\module\module_manager->delete_module(748, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_DMP_PARTNER.) #2
hpbb/db/migration/tool/module.php(459): call_user_func_array(Array, Array) #3
[internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_DMP_PARTNER...') #4
/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5
phpbb/db/migrator.php(661): phpbb\db\migrator->run_step(Array, NULL, false) #6
Timo23
Re: Partner Page
Post by Timo23 »
I tried deleting the extension(Ver. 1.0.4) but got the following error message. (PHPBB Ver. 3.3.1)
Fatal error: Uncaught phpbb\module\exception\module_exception: CANNOT_REMOVE_MODULE in /var/www/user1/html/phpbb/module/module_manager.php:448 Stack trace: #0 /var/www/user1/html/phpbb/db/migration/tool/module.php(425): phpbb\module\module_manager->delete_module(240, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_DMP_PARTNER...') #2 /var/www/user1/html/phpbb/db/migration/tool/module.php(459): call_user_func_array(Array, Array) #3 [internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_DMP_PARTNER...') #4 /var/www/user1/html/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5 /var/www/user1/html/phpbb/db/migrator.php(661): phpbb\db\migrator->run_step(Array, NULL, false) #6 /var/www/user1/html/phpbb/db/migrator.php(554): phpbb\db\migrator->process_da in /var/www/user1/html/phpbb/module/module_manager.php on line 448
SpIdErPiGgY
Re: Partner Page
Post by SpIdErPiGgY »
I see this in ACP:
[phpBB Debug] PHP Notice: in file [ROOT]/ext/dmzx/partner/acp/partner_module.php on line 75: Trying to access array offset on value of type bool
PHP 7.4
phpBB 3.3.3
Re: Partner Page
Will put this on the list to check. :thumbup:
Re: Partner Page
SpIdErPiGgY
Re: Partner Page
NL Translation 1.0.5
PartnerPage1.0.5.zip
PS: I changed <br /> to <br>
And (incl. http://) to (incl. https://)
Tino0815
Re: Partner Page
Post by Tino0815 »
I have the same problem as Timo23
viewtopic.php?p=28653#p28653
Fatal error: Uncaught phpbb\module\exception\module_exception: CANNOT_REMOVE_MODULE in /var/www/tino0815/phpbb/module/module_manager.php:448 Stack trace: #0 /var/www/tino0815/phpbb/db/migration/tool/module.php(425): phpbb\module\module_manager->delete_module(240, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_DMP_PARTNER...') #2 /var/www/tino0815/phpbb/db/migration/tool/module.php(459): call_user_func_array(Array, Array) #3 [internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_DMP_PARTNER...') #4 /var/www/tino0815/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5 /var/www/tino0815/phpbb/db/migrator.php(661): phpbb\db\migrator->run_step(Array, NULL, false) #6 /var/www/tino0815/phpbb/db/migrator.php(554): phpbb\db\migrator->process_da in /var/www/tino0815/phpbb/module/module_manager.php on line 448
umi
Re: Partner Page
Post by umi »
Hi dmzx, would it be possible to add the option to be able to place the partner pages in a desired order?
A greeting and thanks in advance
Re: Partner Page
umi wrote: 20 Jun 2021, 20:42 Hi dmzx, would it be possible to add the option to be able to place the partner pages in a desired order?
This option will be in next release, under test now. :thumbup:
umi
Re: Partner Page
Post by umi »
Cheers bro :beers: :beers: :beers:
Re: Partner Page
SpIdErPiGgY
Re: Partner Page
Thank you for the update, but the arrows don't work :D
Re: Partner Page
Onnozel Manneke wrote: 22 Jun 2021, 17:18 Thank you for the update, but the arrows don't work :D
Did you update or install fresh?
umi
Re: Partner Page
Post by umi »
Tested on phpBB 3.3.4 and working perfectly for me.
Thanks dmzx.
Post Reply
