3.2 & 3.3 Extensions DatabasePartner Page
Partner Page
Extension Name: Partner Page 3.2.x
Special thanks to: martin & Sniper_E
This extension will add a partner page to your forum, where you can list your partners with a description and a logo.
Check permissions for groups that you want to give access to add or view partner page.
If users add a new partner page the Admin will get a notification and need to activate the new partner page in ACP.
- Changed language files.
- Twig update.
- Code update for 3.3.0.
Code update
Partner Page v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `partner`.
  4. Copy the `partner` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/partner/composer.json
  6. Look for `Partner Page` under the Disabled Extensions list, and click its `Enable` link.
This topic has 45 replies
