3.1.x Extensions Database 3.1 / 3.2Nivo Slider
proavia
    Windows 7 Internet Explorer
Re: Nivo Slider
Post by proavia »
Thanks DM - changing the 1 to a 0 in nivo-slider.css fixed the issue.
In prosilver common.css, under /* Inner box-model clearing */ - line 1118 in common.css
.dropdown-extended {
	display: none;
	z-index: 1;
Is that the one for the Notification drop-down - only one I found with z-index <2.
So a lower number (even negative) will move an element lower in the stack - therefore behind other elements with a higher number?
WOW - I learn something new pretty much every time I come here! :tumbsyes:
FranckTH
Re: Nivo Slider
Post by FranckTH »
Nice extension, do you think that's possible to scroll horizontally as youtube gallery addon ?
FranckTH
Re: Nivo Slider
Post by FranckTH »
I'm trying it but i have a problem with height of images
i have two images 90*90 but on my board i see 1120*1120 px :shock:
how to reduce the height please ?
demo :
http://www.graphogames.fr/foe/index.php
bagravi
Re: Nivo Slider
Post by bagravi »
Prev and Next Buttons not displaying
how to correct it
style : prosilver Special Edition
thanks
elsa23
Re: Nivo Slider
Post by elsa23 »
elsa23 wrote: 20 Aug 2016, 20:31 Hi, can not see images bullets.png and arrows.png in nivo slider, how to fix that please
UP ?
sorry for my bad english
Re: Nivo Slider
Hi @all
i would like to add more pics in the nivoslider.
after i have added Pic number 8 i can not add one pic once again.
in the settings under "Controller" i can See only 8 entries
How could i change this to show more pictures in nivo Slider?
thx jan
Re: Nivo Slider
jan_2017 wrote: 27 Oct 2017, 16:54 hi @all
thx jan
Jan for now this is not possible, maybe future release it can be.
Re: Nivo Slider
OK.....thanks for a while :buigen:
bye
Re: Nivo Slider
jan_2017 wrote: 28 Oct 2017, 09:50 OK.....thanks for a while :buigen:
bye
Hello everybody.
I tried a little bit.For all experts here, this is not a wonder of the world.
Here is a description to increase the number of slides.
Please make a backup before you start to change.... :cool:
Find dmzx/nivoslider/controller/settings.php ==> line 95
$this->config->set('slider_sl8_cap',	$this->request->variable('slider_sl8_cap', '',true));
Add after dmzx/nivoslider/controller/settings.php ==> line 95
$this->config->set('slider_sl9_img',	$this->request->variable('slider_sl9_img', '',true));
$this->config->set('slider_sl9_url',	$this->request->variable('slider_sl9_url', '',true));
$this->config->set('slider_sl9_cap',	$this->request->variable('slider_sl9_cap', '',true));
Find dmzx/nivoslider/event/main_listener.php ==> line 96
'SLIDER_SL8_CAP'			=> (string) $this->config['slider_sl8_cap'],
Add after dmzx/nivoslider/event/main_listener.php ==> line 96
'SLIDER_SL9_IMG'			=> (string) $this->config['slider_sl9_img'],
'SLIDER_SL9_URL'			=> (string) $this->config['slider_sl9_url'],
'SLIDER_SL9_CAP'			=> (string) $this->config['slider_sl9_cap'],
Find dmzx/migrations/nivoslider_install.php ==> line 60
array('config.add', array('slider_sl8_cap', '')),
Add after dmzx/migrations/nivoslider_install.php ==> line 60
array('config.add', array('slider_sl9_img', '')),
array('config.add', array('slider_sl9_url', '')),
array('config.add', array('slider_sl9_cap', '')),
Find dmzx/styles/prosilver/template/nivoslider.html ==> line 264+265
								<button type="button" class="removeslide button icon-button delete-icon" title="{L_SLIDER_REMOVE_SLIDE}"></button>
							</dl>
Add after dmzx/styles/prosilver/template/nivoslider.html ==> line 265
							<dl class="panel <!-- IF SLIDER_SL9_IMG -->alwayson<!-- ENDIF -->">
								<dt><label for="slider_sl9_img">{L_SLIDER_SLIDE9}</label></dt>
								<dd>
									<input placeholder="{L_SLIDER_PLACEHOLDER}" title="{L_SLIDER_TITLE_IMAGE}" type="text" class="inputbox" name="slider_sl9_img" id="slider_sl9_img" size="30" value="{SLIDER_SL9_IMG}" />
								</dd>
								<dd>
									<input placeholder="{L_SLIDER_PLACEHOLDER_URL}" title="{L_SLIDER_PLACEHOLDER_URL_TITLE}" type="text" class="inputbox" name="slider_sl9_url" id="slider_sl9_url" size="30" value="{SLIDER_SL9_URL}" />
								</dd>
								<dd>
									<input placeholder="{L_SLIDER_PLACEHOLDER_CAPTION}" title="{L_SLIDER_PLACEHOLDER_CAPTION_TITLE}" type="text" class="inputbox" name="slider_sl9_cap" id="slider_sl9_cap" size="30" value="{SLIDER_SL9_CAP}" />
								</dd>
								<div class="slideimg"><img src="{BOARD_URL}ext/dmzx/nivoslider/images/{SLIDER_SL9_IMG}">
								</div><!-- ENDIF -->
							</dl>
Find dmzx/styles/prosilver/template/slider.html ==> line 19+20
	<!-- IF SLIDER_SL8_URL --><a href="{SLIDER_SL8_URL}"><!-- ENDIF --><!-- IF SLIDER_SL8_IMG --><img src="{BOARD_URL}ext/dmzx/nivoslider/images/{SLIDER_SL8_IMG}" alt="" <!-- IF SLIDER_SL8_CAP -->title="{SLIDER_SL8_CAP}"<!-- ENDIF -->><!-- ENDIF --><!-- IF SLIDER_SL8_URL --></a><!-- ENDIF -->
Add after dmzx/styles/prosilver/template/slider.html ==> line 20
		<!-- IF SLIDER_SL9_URL --><a href="{SLIDER_SL9_URL}"><!-- ENDIF --><!-- IF SLIDER_SL9_IMG --><img src="{BOARD_URL}ext/dmzx/nivoslider/images/{SLIDER_SL9_IMG}" alt="" <!-- IF SLIDER_SL9_CAP -->title="{SLIDER_SL9_CAP}"<!-- ENDIF -->><!-- ENDIF --><!-- IF SLIDER_SL9_URL --></a><!-- ENDIF -->
Find dmzx/nivoslider/language/en/common.php ==> line 71
	'SLIDER_SLIDE8'							=> 'Example 8',
Add after dmzx/nivoslider/language/en/common.php ==> line 71
	'SLIDER_SLIDE9'							=> 'Êxample 9',
This is only a descreption for ONE picture (slide) ore in nivoslider ext.
Upload with ftp in root
Clean cache
Have fun :-D
Re: Nivo Slider
How can i change the position from nivoslider?
can i put this above hederbanner ? Or better into the headerbanner?
thx Jan
miri4ever
Re: Nivo Slider
Post by miri4ever »
How to add Font Awesome Button in front of the name in private menu ?
moffacostanzo
Re: Nivo Slider
Post by moffacostanzo »
This one is compatible with 3.3
thx
venometal
Re: Nivo Slider
Post by venometal »
I am now posting your nivoslider with up to 28 slides if anyone needs this :mml:
Just from your FTP program, upload and replace the files to the exact places as below:
settings.php --> dmzx/nivoslider/controller/ folder
main_listener.php --> dmzx/nivoslider/event/folder
nivoslider_install.php --> dmzx/migrations/folder
nivoslider.html --> dmzx/styles/prosilver/template/folder
slider.html --> dmzx/styles/prosilver/template/ folder
common.php --> dmzx/nivoslider/language/en/ folder
js_op.js --> dmzx/styles/prosilver/template/slider/js/ folder
Thank you for your codings :wave:
