3.2 & 3.3 Extensions Database 3.2 / 3.3Knuffel
dieterlem
    Windows 10 Edge
Re: Knuffel
Post by dieterlem »
Funwave123 wrote: 28 Jul 2021, 21:10 Hi DMZX,
I have a problem with knuffel on phpbb 3.3.4 with the font color. we change the Style from a bright one to a dark one.
So we use a dark skin with white fonts but Knuffel use white fonts too (from Styles?), so we dont see the filled areas/Numbers.
Can I change this into your Addon, or into the Styles proDVGFX on Prosilver ?
Thanks in Advance
Edit:
We colorize the Style from white to green fonts now, we can play again...
Problem solved if you not have a easier solution.
Cheers
Hi I have the same issue. I use a dark style and cant reed the white font at the white Background. How can I change the colour of the font or the background of the textboxes in the extension? I do not find the right part in the files to do so.
Cheers Marcus
dieterlem
    Windows 10 Edge
Re: Knuffel
Post by dieterlem »
Thanks in Advance
Edit:
Cheers
Cheers Marcus
Re: Knuffel
Checked on 3.3.7 and it works. Great extension. Thanks
Fredisland
Re: Knuffel
Post by Fredisland »
phpBB 3.3.10. All is ok !
And here's the FULL FRENCH translation, javascript file has been also translated.
SpIdErPiGgY
Re: Knuffel
Post by SpIdErPiGgY »
Dutch NL translation:
https://www.phpbbextnl.be/viewtopic.php?t=450
.js translation included.
I have an issue on my mobile.
Android 16,Samsung Galaxy s22
🧠 Spiderpiggy Trivia 🐷
Live trivia & chat • Scores, rankings & statistics 🏆
🇧🇪 🇳🇱 For Belgium & Netherlands users only
spiderpiggy.com
eunaumtenhoid
Re: Knuffel
Post by eunaumtenhoid »
Could be compatible with ultimate points
