Extensions Database 3.1 / 3.2 ⇒ 3.1.x Puzzle
3.1.x & 3.2.x
15 given 2
Re: Puzzle
:tumbsyes:
[ Post made via Samsung Galaxy S4 ] Image
testingground
Re: Puzzle
Post by testingground »
This doesnt work on mobile devices.
Is it possible to make it responsive?
15 given 2
Re: Puzzle
testingground wrote: 08 Jun 2016, 16:40 This doesnt work on mobile devices.
Yes this is correct, this needs to be done.
Need to see when I can do it.
Phpbb3
Re: Puzzle
Post by Phpbb3 »
Lovin' this extension, thanks very much! great as is but i played around with the formatting so it would better match (and work with) my theme/style (flatboots)....
gregogreg62
Re: Puzzle
Post by gregogreg62 »
I can not manage this mod
for phpbb 3.2
help me please?
thank
Chaosvariable
Re: Puzzle
Post by Chaosvariable »
Downloading and enabling in the Customize tab, it does not show up in the Extensions tab. Is there a fix or new version?
1 given 2
Re: Puzzle
how can i give user group guest permission to play puzzle game? :question: :roll: :roll:
kaptangula
Re: Puzzle
Post by kaptangula »
Mobile problem does not appear picture
vince
Re: Puzzle
Post by vince »
zardos wrote: 02 May 2016, 14:18 Great extension, :thumbup: just one problem, i can't get the icon to show up and how do i remove the game names in the navbar.
i have the same problem did you get yours fixed ??
1 given 2
Re: Puzzle
This is for phpbb 3.1.
vince
Re: Puzzle
Post by vince »
All works fairly well on 3.3 only a couple small issuses
1 given 2
Re: Puzzle
vince wrote: 11 Jun 2020, 21:28 all works fairly well on 3.3 only a couple small issuses
Try this on 3.3
dmzx_puzzle_1_0_1.zip
faroud
Re: Puzzle
Post by faroud »
Where do you get those puzzles?
Re: Puzzle
It just doesn't display icons. :whistl:
faroud
Re: Puzzle
Post by faroud »
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/puzzle/controller/puzzle.php on line 92: Trying to access array offset on value of type bool
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/puzzle/controller/puzzle.php on line 120: Trying to access array offset on value of type bool
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/puzzle/controller/puzzle.php on line 121: Trying to access array offset on value of type bool
:whistl:
