3.2 & 3.3 Extensions Database 3.2 / 3.3Downloadlog
Re: Downloadlog
Thank you
0 given 2
Re: Downloadlog
This ext somehow make conflixt with
this one
attachmentfluffbuster_3_2_0.zip
how can i fix ?
Hareon
Re: Downloadlog
Post by Hareon »
I have the same problem. Have conflict with the Download Button of File Download.
SpIdErPiGgY
    Android Firefox
Re: Downloadlog
Post by SpIdErPiGgY »
Is it possible to integrate this ext with the inline attachment ext? Because when both are enabled, the attachment shows up twice.....
https://www.phpbb.com/community/viewtop ... #p15992458
🧠 Spiderpiggy Trivia 🐷
Live trivia & chat • Scores, rankings & statistics 🏆
🇧🇪 🇳🇱 For Belgium & Netherlands users only
spiderpiggy.com
Re: Downloadlog
The css you have in that horizontal attachments will be off once you use downlodlog because it adds a dl.filedoawnload to the mix.
I know this because I setup a css file for horizontal attachments here
I worked that up on my local site where I don't have a lot of extensions. Then I pushed it to my live site and it didn't work.
I had to add dl.filedoawnload to that css to get it to work here because I have this downloadlog extension installed.
/* Horizontal Attachments
div.inline-attachment {
	margin: 0 4px 4px 0;
	max-width: 30% !important;
	font-size: 1em;
	font-weight: bold;
	text-align: center;
	float: left;
dl.filedoawnload img.postimage {
    background-color: #A4C0D7;
	padding: 2px;
dl.filedoawnload dt {
    padding: 4px;
    background-color: #6290B7;
    margin: 4px 4px -4px;
dl.filedoawnload dd {
    padding: 4px;
    background-color: #cadceb;
    margin: 4px 4px -5px;
    border: 1px solid #A4C0D7;
    border-top: none;
So dl.filedoawnload may have to be added in your horizontal attachments extension the same way.
SpIdErPiGgY
    Android Firefox
Re: Downloadlog
Thank you Sniper, gonna try that tonight
Re: Downloadlog
I've noticed an if statement out of place in the attachment_file_prepend.html event template if you ever update again. Line 14
As shown here: in this post There is added space where View logs link do not show for us but the <dd> does show, with that space.
		<dd>{% if (U_MCP or U_ACP) %} ... {% endif %}</dd>
That <dd> line does not need to show either if someone does not have permission to view logs. Like the file comment line. Hide it all...
		{% if (U_MCP or U_ACP) %}<dd> ... </dd>{% endif %}
Now this part is just my preference of cleaning up the space. In attached images I moved the image name and file size to <img title" "
	<dt class="attach-image"><img src="{{ _file.U_INLINE_LINK }}" class="postimage" alt="{{ _file.DOWNLOAD_NAME }}" onclick="viewableArea(this);" title="{{ _file.DOWNLOAD_NAME }} ({{ _file.FILESIZE }} {{ _file.SIZE_LANG }})" /></dt>
	{% if _file.COMMENT %}<dd><em>{{ _file.COMMENT }}</em></dd>{% endif %}
	<dd>{{ _file.L_DOWNLOAD_COUNT }}</dd>
Re: Downloadlog
Onnozel Manneke wrote: 11 Jan 2024, 19:34 Is it possible to integrate this ext with the inline attachment ext? Because when both are enabled, the attachment shows up twice.....
I just duplicated the error you had. Dm's downloadlog.css has div.inline-attachment dl.file { display: none; }
Your inline attachment ext css has div.inline-attachment dl.file { display: block; } which loads after and over writes Dm's css.
Just add !important to Dm's two classes in downloadlog.css and only one set of attachments will show.
	display: none !important;
dl.file {
Pingui
Re: Downloadlog
Post by Pingui »
Thx for Update... :thumbup:
Be yourself, except if you're stupid, then it is better that you be another one.
I Amiga
- www.WinUAEspanol.com
I know, my english is very bad, sorry...
