3.3.x Extensions Database 3.2 / 3.3Download System
foxtale
Re: Download System
Post by foxtale »
I have version 1.2.1 installed on my forum.
How to update to 1.2.2?
Should i replace the the 1.2.1 files with the updated ones?
Many thanks for your work! :thumbup:
Banned
Banned
    Mac OS X Firefox
Re: Download System
You must first disable the current version in your ACP before sending the new version files to the server.
Once done activate the new version from your ACP
Re: Download System
foxtale wrote: 10 Feb 2025, 20:33 I have version 1.2.1 installed on my forum.
Disable extension, don't delete data!!
Upload all new files except the "files" folder leave that in place with all your previous files in there.
Then enable the extension again in ACP.
Banned
Banned
    Mac OS X Firefox
Re: Download System
dmzx wrote: 10 Feb 2025, 20:45 Upload all new files except the "files" folder leave that in place with all your previous files in there.
It's not a problem because the "files" folder of the new version is empty, no risk of deleting the existing files from the server.
foxtale
Re: Download System
Post by foxtale »
ssl wrote: 10 Feb 2025, 20:42 You must first disable the current version in your ACP before sending the new version files to the server.
Thanks for the info! :eusa_dance:
Update done! :tumbsyes:
Avangard
    Windows 10 Edge
Re: Download System
Post by Avangard »
Hello! There is a mention of the cost of downloads in the language files. But I did not find where this can be configured in the settings. Is this extension compatible with Ultimate Points?
foxtale
Re: Download System
Post by foxtale »
Hello to all!
How can i fix this?
Items are not aligned :wtf:
I'm using lucid_lime style on my forum.
iorG19
    unknown Chrome
Re: Download System
Post by iorG19 »
// Romanian translation for this extension; download and upload to the forum's /ext directory.
// Traducere în limba română a acestei extensii: descarcă și urcă în directorul /ext al forumului.
dmzx-downloadsystem-1.2.2_ro.zip
Pe forumul meu de demonstratie puteti vizualiza extensia tradusa.
Dacă sesizați vreo eroare de traducere, vă rog să mi-o comunicați.
flumsi
Re: Download System
Post by flumsi »
Hello everyone
Download system 1.2.2 & phpbb3 3.3.1.4
I'm thrilled, it's really well done and has the appropriate CSS adjustments :eusa_dance:
ACP phpbb3 Standard "Enable URL rewriting"
Unfortunately, our provider doesn't offer it, so I had to get my hands dirty with your YouTube Gallery because app.php was missing from the video links.
ext/dmzx/youtubegallery/controller/youtubegallery.php
Original:
'VIDEO_LINK' => append_sid("{$board_url}/video", 'mode=view&id=' . $row['video_id']),
Change to:
'VIDEO_LINK' => append_sid("{$board_url}/app.php/video", 'mode=view&id=' . $row['video_id']),
I'm having roughly the same problem now, but with your download system.
If I enable it to create a topic for each new download with the appropriate forum ID, it works perfectly, except for one glitch.
we have a new download!
Title: testerlisi2
Description: testerlisi2
Category: test
Click here to go to the download page!
Have fun!
The link marked "here" in the generated text unfortunately doesn't work.
../forum/downloadsystemcat?id=1
The browser displays a 404 error: "The requested URL was not found on this server."
For my needs, the link in the generated text should look like this:
../forum/app.php/downloadsystemcat?id=1
Thank you for your help
Ecron
Re: Download System
Post by Ecron »
My hosting provider updated PHP from 8.0 to 8.3 and now it's not working anymore. What can I do? Please help!
Ecron
Re: Download System
Post by Ecron »
Re: Download System
It works on php 8.3 with no issues. Make sure you have the latest version of the ext.
Danny78
Re: Download System
Post by Danny78 »
Will this allow external download links from Google Drive
Re: Download System
