3.3.x Extensions Database 3.2 / 3.3Download System
Re: Download System
mh254 wrote: 26 Jan 2023, 11:49 How do you mean this? Use nginx as Reverse Proxy and let Apache run the PHP code?
I use here:
mh254
Re: Download System
Post by mh254 »
When I use Fast-CGI with apache2 everything is fine, when I switch to nginx with Fast-CGI I get the network error when downloading files.
Re: Download System
mh254 wrote: 31 Jan 2023, 12:11 When I use Fast-CGI with apache2 everything is fine, when I switch to nginx with Fast-CGI I get the network error when downloading files.
Use apache2 nginx with PHP-FPM Fast-CGI is mainly for apache it will work with nginx but is more trouble than it's worth.
Hamidouki-dz
Re: Download System
Post by Hamidouki-dz »
j'ai changé un nom de domaine du forum par un autre :
une migration mise à jour 3.2.7 vers 3.3.9
puis transfert du forum vers un autre nom de domaine .
actuellement tous marche bien, une partie du téléchargement d'un fichier depuis l'extension télécharge le système me dit que l'ID erreur.
Re: Download System
Hamidouki-dz wrote: 02 Feb 2023, 18:30 Hello
Pm me test account
nexosenz
Re: Download System
Post by nexosenz »
nexosenz wrote: 27 Jan 2023, 21:10 hello,
sorry for my english, it's a google translation.
I wish I could suppress the display of this, even if we have the permissions.
ideally, with a yes/no setting in the configuration settings.
I will access the system directly with a link "url/downloadsystem"
thank you very much
can you help me please ? :-)
Re: Download System
Your database has your old domain in the download id this is an easy fix in you know how to edit the database.
Hamidouki-dz
Re: Download System
I only modified the internal links in the php _post file, however the problem with the ID to download the files no idea
Banned
Banned
Re: Download System
Il doit parler de ça qui se trouve dans les paramètres de l'extension
Enfin on ne comprend pas trop ce qu'il veut dire avec "the ID to download"
Hamidouki-dz
    Windows 10 Edge
Re: Download System
ssl wrote: 04 Feb 2023, 13:43 Il doit parler de ça qui se trouve dans les paramètres de l'extension
thanks solved , but i have this error when i click on UPLOAD
Parse error: syntax error, unexpected '=' in /home/powers76/public_html/ext/dmzx/downloadsystem/controller/downloadupload.php on line 360
Re: Download System
Hamidouki-dz wrote: 08 Feb 2023, 00:37
Do you use latest version 1.2.0 ?
Hamidouki-dz
Re: Download System
Yes update it , the error still persist.
Re: Download System
Hamidouki-dz wrote: 08 Feb 2023, 10:01 Yes update it , the error still persist.
What php version do you use?
Hamidouki-dz
Re: Download System
Re: Download System
Hamidouki-dz wrote: 08 Feb 2023, 10:04 Screenshot_20230208_100424_Chrome.jpg
Check in you ACP main page what version it is.
