3.3.x Extensions Database 3.2 / 3.3Download System
rammstein
Re: Download System
Post by rammstein »
No I have not in the left side panel.
download this ext from from here?
rammstein
Re: Download System
Post by rammstein »
Ok i found it thank you
Hamidouki-dz
Re: Download System
Post by Hamidouki-dz »
Midway wrote: 08 Aug 2021, 13:41 repared replace
if ($key ??= $row2['download_cat_id'])
by
if ($key == $row2['download_cat_id'])
THE SAME PROBLEM
I replaced and it didn't work ( phpbb 3.3.9 )
file : admin_controller.php
result :
Parse error: syntax error, unexpected '=' in /home/powers76/public_html/ext/dmzx/downloadsystem/controller/downloadupload.php on line 360
mh254
Re: Download System
Post by mh254 »
I have an issue with this extension and nginx.
Everything is working fine as long as I use apache2 as web server. When I switch to nginx, I can't download files anymore. I always get a network error in browser and nothing in nginx logs or php-fci logs.
Board is running on phpbb 3.2 latest version, latest extension version on nginx 1.18 and php7.4-fpm.
If you need additional information, please let me know.
Re: Download System
mh254 wrote: 25 Jan 2023, 07:07 I have an issue with this extension and nginx.
Running here on nginx-apache can you try this?
mh254
Re: Download System
Post by mh254 »
How do you mean this? Use nginx as Reverse Proxy and let Apache run the PHP code?
nexosenz
Re: Download System
Post by nexosenz »
sorry for my english, it's a google translation.
I wish I could suppress the display of this, even if we have the permissions.
ideally, with a yes/no setting in the configuration settings.
I will access the system directly with a link "url/downloadsystem"
thank you very much
nexosenz
Re: Download System
Post by nexosenz »
I can't use the extension. No downloading is possible.
With small files, or large files, impossible.
The link seems correct, after clicking, I choose the place of registration, then there is a network error immediately.
Re: Download System
nexosenz wrote: 30 Jan 2023, 17:39 Hello,
Pm me test account
Re: Download System
Go to this file in the extension on your server:
https://github.com/dmzx/Download-System ... d.php#L107
make it:
// ob_end_flush();
Clear cache in ACP and try again.
nexosenz
Re: Download System
Post by nexosenz »
Same problem :sad: :sad:
Re: Download System
Ok will look into this when back at home. Leave account open for now.
nexosenz
Re: Download System
Post by nexosenz »
Ok thanks :wink:
Re: Download System
nexosenz wrote: 30 Jan 2023, 20:57 ok thanks :wink:
Can you set admin account
nexosenz
Re: Download System
Post by nexosenz »
It's done
