3.3.x Extensions Database 3.2 / 3.3Download System
BPanther
    unknown Mozilla
Re: Download System
Post by BPanther »
V1.1.9 works - thanks. :tumbsyes:
Re: Download System
BPanther
    unknown Mozilla
Re: Download System
Post by BPanther »
Thanks, also v1.2.0 works, seems to be it was only a problem with 1.1.8. :tumbsyes:
Midway
Re: Download System
Post by Midway »
I have an error with upload
Parse error: syntax error, unexpected '=' in ext/dmzx/downloadsystem/controller/downloadupload.php on line 360
Midway
Re: Download System
Post by Midway »
Repared replace
if ($key ??= $row2['download_cat_id'])
by
if ($key == $row2['download_cat_id'])
KumbaraWebNetwork
    Windows 10 Edge
Re: Download System
Post by KumbaraWebNetwork »
Thank you for the extension, even though It does not appear in extension manager.
Re: Download System
KumbaraWebNetwork wrote: 11 Oct 2021, 22:22 Thank you for the extension, even though It does not appear in extension manager.
jordon
Re: Download System
Post by jordon »
1.How can I add another extension like .psd
2. Image
Any upload bag tells me that the file is too big and has 9kib
3.Image
In acp as well
4.Can't put file directly without category?
PS: 3.3.5
This linie
if ($unit == 'MB')
$multiplier = 1048576;
else if ($unit == 'KB')
$multiplier = 1024;
Schneewitchen
Re: Download System
Post by Schneewitchen »
Thanks for the great addition :thumbup:
Re: Download System
rammstein
Re: Download System
Post by rammstein »
No compatible 3.3.8 ?
Banned
Banned
Re: Download System
rammstein wrote: 20 Jul 2022, 14:09 no compatible 3.3.8 ?
This extension work fine with phpBB version 3.3.8
rammstein
Re: Download System
Post by rammstein »
I installed this extensions on 3.3.8 but I can't find in the extensions to install
Re: Download System
Ext tab then its in the left side panel.
Banned
Banned
Re: Download System
rammstein wrote: 26 Jul 2022, 10:22 I installed this extensions on 3.3.8 but I can't find in the extensions to install
You download this ext from GitHub or from here?
