3.1.x Extensions Database 3.1 / 3.2Button menu
DB1953
Re: Button menu
Post by DB1953 »
I'm having problems being able to move "sub button" around (the order).
hey just won't go. (sometimes they will, but mostly they won't.
This program works great except for this problem. I can't get them in the order I want unless I delete them and add them back in in the order I want. That's a lot of trouble.
D
DB1953
Re: Button menu
Post by DB1953 »
Nothing?
rogerio24
    Linux Firefox
Re: Button menu
Post by rogerio24 »
This work for phpbb 3.2.1?
Sniper_E Online
Re: Button menu
DB1953 wrote: 17 Aug 2017, 17:43Nothing?
Nope. Put them in the order you want them in and walk away.
rogerio24 wrote: 29 Sep 2017, 15:09 This work for phpbb 3.2.1?
I installed it on 3.2.1 with no problems except for not being able to re-ordering them. :eek:
Exabot
    Mac OS X Firefox
Re: Button menu
Post by Exabot »
This work for phpBB 3.3? I guess not...
Re: Button menu
It's listed under 3.1
Exabot
    Mac OS X Firefox
Re: Button menu
Post by Exabot »
What needs to be changed in CSS to remove it?
Screen Recording 2020-04-10 at 15.21.05.mov
Re: Button menu
Images and video's are no good a link and detailed info of what you want is needed.
Exabot
    Mac OS X Firefox
Re: Button menu
Post by Exabot »
Remove it with a shadow or similar. To prevent the button from flashing.
Xxxbennyxxx
Re: Button menu
Post by Xxxbennyxxx »
Will there be updates for 3.3?
I would also like to change the button menu.
Re: Button menu
It works on 3.3 and 3.3.1
Xxxbennyxxx
Re: Button menu
martin wrote: 03 Aug 2020, 02:29 it works on 3.3 and 3.3.1
ERROR
phpBB is een foutmelding tegengekomen tijdens het bouwen van de container, veroorzaakt door een geïnstalleerde extensie. Om deze reden zijn alle extensies tijdelijk uitgeschakeld. Probeer de cache van je forum te legen. Alle extensies worden automatische ingeschakeld als de foutmelding is opgelost. Als deze foutmelding zich blijft voordoen, bezoek dan ons support forum via phpbb.nl.
Uitzondering: The file "/home/deb78240n4/domains/zelfbeschadiging.be/public_html/ext/dmzx/buttonmenu/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 7 (near "- @service_container").
#0 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/deb78240n...')
#1 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/phpbb/di/container_builder.php(203): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/common.php(115): phpbb\di\container_builder->get_container()
#9 /home/deb78240n4/domains/zelfbeschadiging.be/public_html/adm/index.php(23): require('/home/deb78240n...')
#10 {main}
Re: Button menu
My bad i was thinking of the buttons ext.
but yes its a simple change to make it work.
Xxxbennyxxx
Re: Button menu
These changes can be found on phpBB.com. But unfortunately this gives the same mistake. Also emptying cashe does not help
imports:
    - { resource: tables.yml }
services:
    dmzx.buttonmenu.listener:
        class: dmzx\buttonmenu\event\listener
        arguments:
            - '@service_container'
            - '@config'
            - '@template'
            - '@user'
            - '@dbal.conn'
            - '%dmzx.buttonmenu.table.menu_buttons%'
            - '%dmzx.buttonmenu.table.menu_colors%'
        tags:
            - { name: event.listener }
    dmzx.buttonmenu.table.menu_buttons: '%core.table_prefix%menu_buttons'
    dmzx.buttonmenu.table.menu_colors: '%core.table_prefix%menu_colors'
Edit: Fixed
Delete date and reinstall
But how do I get the button menu above the header ?
Re: Button menu
:wall:
works on 3.3 and 3.3.1 tried and tested well the install anyway.
dmzx_buttonmenu_1_0_0.zip
