3.1.x Extensions Database 3.1 / 3.2 ⇒ Top Stats
stockton88
Re: Top Stats
If I would like to translate the files.
Only the config.file need to be translated?
Re: Top Stats
Copy / Paste the en folder in notifyadmin\language and change the folder name to the other languages you use.stockton88 wrote:If I would like to translate the files.
Adazbobaby
Re: Top Stats
The links are broken on my forum and I cant see where to fix it.
The Mess Hall - Index page
404 Not Found
404 Not Found
Re: Top Stats
Is this only with the 10 Most viewed topicsdazbobaby wrote:The links are broken on my forum and I cant see where to fix it.
404 Not Found
Adazbobaby
Re: Top Stats
It is, all the other top stats are fine, just the top 10 most viewed.
example:
Working Link -
Not working link (top stats formatting) -
example:
Working Link -
http://mess-hall.co.uk/viewtopic.php?f=93&t=2328Code: Select all
http://mess-hall.co.uk/viewtopic.?f=93&t=&view=unread#unread-
Re: Top Stats
Can you check these lines in listener.php
topstats/listener.php at master · dmzx/topstats · GitHub
Adazbobaby
Re: Top Stats
Sorted DMZX - Many thanks to you :)
looks like this was the issue?
mine:
Github:
(($row['forum_id'])mine:
$view_topic_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . (($row['forum_id']) ? $row['forum_id'] : $forum_id) . '&t=' . $topic_id . '&view=unread') . '#unread' ;
$view_first_poster = append_sid("{$this->phpbb_root_path}memberlist.$this->phpEx", 'mode=viewprofile' . '&u=' . $row['topic_poster']);
$view_last_poster = append_sid("{$this->phpbb_root_path}memberlist.$this->phpEx", 'mode=viewprofile' . '&u=' . $row['topic_last_poster_id']);Code: Select all
$view_topic_url = append_sid("{$this->phpbb_root_path}viewtopic.$this->phpEx", 'f=' . $row['forum_id'] . '&t=' . $row['topic_id']);
teevee22
Re: Top Stats
Thank you so much for this extension. The scrolling recent topics was something our forum was really missing when we upgraded to 3.1.
I do have a request...either as an addition to the extension or perhaps just a bit of code addition that I can make--I'd like to be able to tell on the scrolling recent topics when there are unread posts in the topic. It can be a topic icon change or a topic title color change, or even adding the word "unread" to the end of the topic title in the scroll box.
Is this something that could be done without too much work on your end?
-edited- Oops, I think perhaps I should have posted this on the Question forum. Sorry about that!
teevee22
Re: Top Stats
Sorry to be such a pain, but would it be better if I repost this request in the "Questions" forum?
Or is this request just not possible with this extension?
Re: Top Stats
For now this is not possible and I will "add" it to the to do list to be checked if possible.teevee22 wrote:Sorry to be such a pain, but would it be better if I repost this request in the "Questions" forum?![]()
teevee22
Re: Top Stats
Thanks so much for your reply and for putting it on your list.dmzx wrote:For now this is not possible and I will "add" it to the to do list to be checked if possible.teevee22 wrote:Sorry to be such a pain, but would it be better if I repost this request in the "Questions" forum?![]()
Perhaps you can get together with this extension author and come up with the best of both...the wonderful scroll AND unread topic icons!
https://www.phpbb.com/customise/db/exte ... _topics_2/
themission
- Donator
Re: Top Stats
Hi, Do you know how i would add an Avatar next to the most viewed topics ? have got Top 5 working with an avatar but empty at the mo on most viewed ?
Null
Re: Top Stats
In 10 recent active topics, "Replies" colum is wrong:
Should be 0/0/27 or "replies" column should be called "Posts" column.
