Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 Loading indicator
3.1.x & 3.2.x
1 given 2
Re: Loading indicator
I will need to install it and test it as i no longer use it :thumbup:
1 given 2
You need to add a new file into download system also make a change in loading ext (tried and tested if it dont work for you then your browser is holding the js)
loading ext /prosilver/template/event/overall_footer_after.html
<!-- INCLUDEJS loading_indicator.js -->
<!-- IF (SCRIPT_NAME == 'index' or SCRIPT_NAME == 'viewtopic') -->
<!-- INCLUDEJS jquery-2.0.0.min.js -->
	$(function() {
    		$("#loading-indicator").delay(5000).fadeOut(0);
</script>
	$(function() {
</script>
now upload this folder into the download system and purge boards cache also your browser once done the loading indicator last for 5 seconds ( note it will only work once on a page unless the page is refreshed) looking into a fix for this.
New html file also needed js files
download_ext_loader_files.zip
Little demo for those who will say it dont work hahaha https://www.youtube.com/watch?v=Mgwgh3lx7Po
kaspir
Post by kaspir »
It doesn't work.
:eusa_dance: Just kidding! Worked immediately after cache purge! :thumbup:
Check out phpBB contributions & extension downloads. :P
1 given 2
Cool beans i'm looking for a way to refresh the js after the first click if you some how come across a way as it only works the once on a page.
kaspir
Post by kaspir »
martin wrote: 14 Feb 2017, 11:36 cool beans i'm looking for a way to refresh the js after the first click if you some how come across a way as it only works the once on a page.
js is my nemesis, as I can understand some php, all html and css.. not JS! :rolling: I almost always resort to google, BUT I don't mind putting in some time to see what I can search for ya.. there is always someone out there who did it first, or so it seems.
Thanks for the help, as always Martin! I will try and invest some of my time for you, and see what I can come up with on google, no prob! I shall pm any ideas, wouldn't want this topic to get hi-jacked with false, untested codes or anything.
17 given 2
1 given 2
Does updated files include the fix for file downloads clicks ? if not il add them.
kaspir
Post by kaspir »
martin wrote: 05 Mar 2017, 13:48 does updated files include the fix for file downloads clicks ? if not il add them.
Nope, I just checked that immediately. :)
I also dropped the js conversion, and just did your original IF SCRIPT var. Just seems to be smoother that way.
Galixte de EzCom
FRENCH translation for the Loading indicator extension
Post by Galixte de EzCom »
this is the FRENCH translation for the Loading indicator extension, available here: https://www.phpbb.com/customise/db/exte ... 16#p590416 & http://www.ezcom-fr.com/viewtopic.php?f=11&t=574.
Communauté EzCom
Image « Traductions d’extensions & styles pour phpBB 3.1.x & 3.2.x ».
seacoast
Post by seacoast »
I have an animated gif I want to use...but I want to use ONLY the gif. No rounded box effect and no "Loading..." displayed. Can this be easily accomplished?
Thank you!
eunaumtenhoid
Post by eunaumtenhoid »
Raheem
Post by Raheem »
The indicator will stay after download, how to disable it at all if download button clicked? Any idea?
1 given 2
Raheem1 wrote: 06 Sep 2018, 16:22 The indicator will stay after download, how to disable it at all if download button clicked? Any idea?
And that is why i made one that works just as the page has loaded :rolling: and not during loading.
Raheem
Post by Raheem »
martin wrote: 06 Sep 2018, 17:54 And that is why i made one that works just as the page has loaded :rolling: and not during loading.
I tested yours but the indicator appears after event is done... If it can be like phpbb one it will be better.
Azuwi
Post by Azuwi »
seacoast wrote: 25 Oct 2017, 17:14 I have an animated gif I want to use...but I want to use ONLY the gif. No rounded box effect and no "Loading..." displayed. Can this be easily accomplished?
Thank you!
I'm also curious about this, and also if there is loading "window" for other themes/styles? not the prosilver one.
