just read them straight out of the database
Extensions Database 3.2 / 3.3 ⇒ 3.2.x Read Members PM 3.2.x
AHartenheer
Re: Read Members PM 3.2.x
Small problem.
It is indicated that it can only be seen before (only user_id 2)
Another administrator has a different ID, have tested their user permissions
And can just see it. How do I adjust this?
@DMZX mijn e-mail is nog steeds niet aangepast naar info@vogel-verkoop-markt.nl
They may be able to see the link but the user id 2 should stop them from reading.
edit i tested as another admin also set his as founder and only user id 2 can read them .
AHartenheer
If I use his [User Permits Test], I can just open itmartin wrote: 16 Mar 2018, 15:14 They may be able to see the link but the user id 2 should stop them from reading.
He is 2nd manager
Edited my post above and yes if your testing using a users perms you will get access as your still using the user id account but dont panic the user in question can not read them its impossible as its set to user id 2.
EnigmaTek
Exactly how would I tailor this to my current template?
I'm using GamesPro for phpbb3.2. I used to use the old 3.1 version, which was in the ACP, but with 3.2 and this new style applied, I'm not getting your fa icon or the link.
EDIT: Please ignore the above, I simply told my current theme to inherit from prosilver, and it's working now. :) Thanks for excellent extensions, DMZX!
First post updated with some extra code in the 2nd download folder (the orange one)
Galixte de EzCom
FRENCH translation of the Read Members PM 3.2.x
this is the FRENCH tranlation of the Read Members PM 3.2.x, available here & on the EzCom Community:
Patrick-06
Hello !
I do not see the messages.
Please help me.
phpbb 3.2.3
Please help me.
phpbb 3.2.3
Try my version it working fine on 3.2.3 altho its the same files as here i just have a few extra edits in it.
Patrick-06
It works perfectly. Thank you !
Midway
- Translators
Re: FRENCH tranlation of the Read Members PM 3.2.x
Hi in line 56 I seeGalixte de EzCom wrote: 29 Jul 2018, 21:54 Hi,
Read Members PM v1.0.1 French language pack.zip
'READ_MESSAGE' => 'Cliquer pour to ce message',Code: Select all
'READ_MESSAGE' => 'Cliquer pour lire ce message',Re: Read Members PM 3.2.x
Cool beans.
Galixte de EzCom
Fixed, thanks.Midway wrote: 15 Oct 2018, 09:40Hi in line 56 I seeGalixte de EzCom wrote: 29 Jul 2018, 21:54 Hi,
Read Members PM v1.0.1 French language pack.zipthe good translation isCode: Select all
