3.2.x Extensions Database 3.2 / 3.3Did You Know 3.2.x
Salva66
Re: Did You Know 3.2.x
Post by Salva66 »
Shenzy wrote: 17 Feb 2018, 23:37 Hello,
is there a way to display this only on the forum index?
Edit: I found it out by myself. For those also interested, you have to rename the viewforum_forum_title_before.html in ext -> dmzx -> didyouknow -> styles -> all -> template -> event to index_body_markforums_after.html and it will show up just above the forum list.
... and when you rename viewforum_forum_title_before.html in overall_header_content_before.html, then:
Did You Know_1.0.5-Slovenian.zip
Yml check he says:
Find tables.yml
parameters:
    dmzx.didyouknow.table.did.you.know: %core.table_prefix%did_you_know
Replace with tables.yml
parameters:
    dmzx.didyouknow.table.did.you.know: '%core.table_prefix%did_you_know'
