Its working here but will check some items and post it soon.
3.1.x Extensions Database 3.1 / 3.2 ⇒ Nivo Slider
Re: Nivo Slider
zardos
Re: Nivo Slider
Just tried it again, not working on home page but will work on topics page.
zardos
Re: Nivo Slider
Just pinned it, loadingindicator stops Nivo slider from showing on index page on my test sever and real server. I turned of all ext and deleted all data, then one by one turned back on, all work fine but for loading indicator.
Re: Nivo Slider
Strange, works here..zardos wrote: 11 May 2016, 22:28 Just pinned it, loadingindicator stops Nivo slider from showing on index page on my test sever and real server. I turned of all ext and deleted all data, then one by one turned back on, all work fine but for loading indicator.![]()
Will check on it.
Thunder
Re: Nivo Slider
I uploaded 2 jpg images in the directory images. The size of the images is 630x300
When I look at me the slider, he makes the images suddenly 1.493px × 711
Why ? Where can you please change the size he also accepts as the image is. ?
Thank you in advance.
elsa23
Re: Nivo Slider
Hi, can not see images bullets.png and arrows.png in nivo slider, how to fix that please
sorry for my bad english
Fast_Eddie
Fast_Eddie
Re: Nivo Slider
Double checked the permissions system and could find nothing for the slider.
Re: Nivo Slider
Check https://github.com/dmzx/Nivo-Slider/blo ... re.html#L2
And delete 3x and S_USER_LOGGED_IN
Fast_Eddie
Re: Nivo Slider
Thanks DM ! I'll try it out tonight!
proavia
Re: Nivo Slider
Has anyone else experienced - with the slider active - that if you have a notification, the drop-down notification box is covered by the slider?
Or is it just me?
Any help is appreciated!
Or is it just me?
Re: Nivo Slider
Check in nivo-slider.css this part:proavia wrote: 19 Nov 2016, 05:37 Has anyone else experienced - with the slider active - that if you have a notification, the drop-down notification box is covered by the slider?
Or is it just me?![]()
.nivoSlider {
position:relative;
width:100%;
height:auto;
overflow: hidden;
z-index: 1;
}The z-index: 1; will set it in front or aft.
Also check the z-index of the notification box.
proavia
Re: Nivo Slider
Thanks Dm - will check that this afternoon when I get home.
So either 1 or 0?
[ Post made via iPhone ]
So either 1 or 0?
