fix it pleasedmzx wrote:.
3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Topic Index
Re: Topic Index
Man... if this could read the same event_name.html templates that all the extensions use and order them A B C you would be a hero!
Zoni
Re: Topic Index
Same bug, how I can fix it?MagicalFire wrote: 14 Aug 2016, 09:35 Hello, I found an error
after adding the link in the post duplicate it
Zoni
Re: Topic Index
C'mon staff! You know how make an extension and you don't know how fix a little bug?Zoni wrote: 15 Oct 2016, 01:16Same bug, how I can fix it?MagicalFire wrote: 14 Aug 2016, 09:35 Hello, I found an error
There is another topic list for phpBB 3.1?
Re: Topic Index
Yes will look into it when I have some time.
Zoni
Re: Topic Index
This is the bug:
A phpBB user write:
A phpBB user write:
If help you..I'm not familiar with this EXT, but a quick scan brings two files to my attention...
ext/styles/all/template/event/viewtopic_body_postrow_post_details_before.html
There is a possible rogue <!-- at the very end (Unless it's intended of course!
And
ext/styles/all/template/event/viewtopic_body_postrow_post_notices_before.html
This file just contains --> which may also be intended!
Best to see what the Author says, just posting these here in case it helps him. :) I suspect they may be like that on purpose to comment something out...
Re: Topic Index
This ext was created back in 25 Nov 2015.
Phpbb has moved on a few versions since then new events have been added and a few things have changed so most extensions will need a small update but updates take time when you have so many to do.
Zoni
Re: Topic Index
So Martin these little bug is a big bug?
And now for phpBB 3.1.9 there isn't a topic list ext that work?
Re: Topic Index
I did not say that.Zoni wrote: 16 Oct 2016, 14:16 So Martin these little bug is a big bug?
Il put it in the short way it will be updated if and when.
Tarantino
Re: Topic Index
It seems this ext was based on official_topic_index, but it was based on last 2.0.2 version or a older one?
I'm just curious.
I'm just curious.
Gio
Re: Topic Index
Topic not show up on the forum?
and after install i get this
Rick8
Re: Topic Index
I have the same problem, if you can fix it on the next update would be marvelous, thx in advance!Zoni wrote: 16 Oct 2016, 13:45 This is the bug:
A phpBB user write:
And
