3.1 & 3.2 Extensions Database 3.1 / 3.2Support Ticket
Re: Support Ticket
pedala
Re: Support Ticket
Post by pedala »
Thx dude, can I change the options ? from "posting_editor_subject_after"
Re: Support Ticket
Without php knowledge will not so simpel.
not only this file needs to be change...
what do you need exactly?
bye Jan
pedala
Re: Support Ticket
Post by pedala »
jan_2017 wrote: 15 Feb 2017, 17:28 without php knowledge will not so simpel.
bye Jan
I have a game server (Flyff), I wanted to use this system for players to report errors, technical problems or complaints.
Re: Support Ticket
Write me a pm and tell me in what line what should be put in.
My template I can certainly adapt to you
bye jan
qnexo
Re: Support Ticket
Post by qnexo »
French language
Support Ticket v1.0.2
supportticket fr.zip
Re: Support Ticket
qnexo wrote: 27 Feb 2017, 04:08 French language
Thanks added :thumbup:
toutou311
Re: Support Ticket
Post by toutou311 »
Maybe someone can help me, this is a wonderful extension that i wanted to duplicate for another purpose.
I'm using this extension for a "presentation posting template" and it works verry well !!!
Then i just want to duplicate the extension to make another template on a different forum. Is that possible ?
I first duplicated all the file, and changed some values but it seems not to work at all, i just cant activate and disable the one i want= > All ON or all OFF.
Is that possible to duplicate the extension in another name/values to avoid crosstalk between each copy ?
Thanks in advance,
Seraster
thunderchero
Re: Support Ticket
Post by thunderchero »
I was testing this for my forum and noticed, if you preview support topic twice, it will add support questions to text area twice.
would it be possible to close support topic questions after previewing first time and return to normal compose new topic?
thunderchero
thunderchero
Re: Support Ticket
Also when making some changes I noticed a small error in listener.php
On line 179
$page_data['STS_MODS']			= $this->request->variable('phpbbknowledge', 0);
Should be
$page_data['STS_MODS']			= $this->request->variable('phpbbmods', 0);
And it is missing line for STS_KNOWLEDGE
$page_data[STS_KNOWLEDGE]			= $this->request->variable(' phpbbknowledge ', 0);
without this form resets to yes for extensions and beginner for knowledge.
Re: Support Ticket
I have got an other problem.
I need two different support tickets.
Is this workable?
Bye Jan
Re: Support Ticket
thunderchero wrote: 27 Apr 2017, 01:38 I was testing this for my forum and noticed, if you preview support topic twice, it will add support questions to text area twice.
thunderchero
Do you have any screenshots? Some users have the same problems in my forum.
Re: Support Ticket
Re: Support Ticket
dmzx wrote: 07 May 2017, 12:34First post updated
What do you you change exactly?
Thx bye Jan
Re: Support Ticket
jan_2017 wrote: 07 May 2017, 12:57
Thx bye Jan
See changes here https://github.com/dmzx/Support-Ticket/ ... 1c3537dbbf
