3.2 & 3.3 Extensions Database 3.2 / 3.3Downloadlog
Re: Downloadlog
Super! Thank you!
dani50
Re: Downloadlog
Post by dani50 »
I need help, I installed a bootlike theme and this extension doesn't work for me, you can help me. Thanks.
www.electronicforum.ro
8 given 1
Re: Downloadlog
awr
Re: Downloadlog
Post by awr »
Downloadlog Turkish Translate pack updated
tr.rar
qwerty541
Re: Downloadlog
Post by qwerty541 »
PhpBB 3.3.1
Downloadlog 1.0.4
SQL ERROR [ mysqli ]
Unknown column 'd.downloadslog_counter_user' in 'field list' [1054]
SQL
SELECT d.user_id, d.down_date, d.downloadslog_counter_user, u.user_id, u.username, u.user_colour FROM phpbb_userdownloadslog d, phpbb_users u WHERE u.user_id = d.user_id AND file_id = 158 ORDER BY d.down_date DESC LIMIT 100
Downloadlog 1.0.2 — working
Re: Downloadlog
On phpBB 3.3.2
Updated downloadlog from v1.0.3 to 1.0.4 and all is working Great!
SpIdErPiGgY
Re: Downloadlog
Post by SpIdErPiGgY »
Blue color with a grey shadow, new arrow image & NL language files
downloadlogbluenl.zip
🧠 Spiderpiggy Trivia 🐷
Live trivia & chat • Scores, rankings & statistics 🏆
🇧🇪 🇳🇱 For Belgium & Netherlands users only
spiderpiggy.com
xest
Re: Downloadlog
Post by xest »
Hi, using 1.0.4, working great so far.
Is it possible to access the downloadlog database directly so i can make a report with all the doenloads?
I've searched the phpbb dtabase but found no downloadlog there.
can you point me in the right direction?
thhnk you
1 given 1
Re: Downloadlog
xest
Re: Downloadlog
Post by xest »
Yes, it was phpmyadmin not showing the table on the navigation tree.
I see it now.
thank you and sorry :wall: :wall: :wall:
xest
Re: Downloadlog
Post by xest »
Hi. i'm having trouble with non admin users viewing the log.
The View Log link appears only to admins and moderators, but when a moderator clicks on it to view the Log, the pop up says "You don't have access to this section"
Which permission should users have, besides moderator (or Global Moderator, as i tried this already) to be able to see the log?
And also i don't want to give admin permissions to moderators, as you can imagine...
Thank you!
1 given 1
Re: Downloadlog
From memory only admins can see who downloaded.
Moderators can see the link but not allowed to see the log.
Re: Downloadlog
Well if moderators can't see the logs then they should not be able to see the link to the logs. Is there a if statement missing somewhere?
xest
Re: Downloadlog
Post by xest »
Hi, just in case anyone needs moderators to be able to access download log (not just view the link)
version 1.0.4 installed
Open ext\dmzx\downloadlog\controller\downloadlog.php and change this line:
if (!$this->auth->acl_get('a_'))
if (!$this->auth->acl_get('a_') && !$this->auth->acl_get('m_'))
don't touch anything else. && is AND
now moderators can see the link anf when clicking on it, they can view the download log.
(modx the code above by martin)
nou nou
    Windows 10 Edge
Re: Downloadlog
Post by nou nou »
Hello!
I found a bit of an obscure issue with Downloadlog. There's a BBCode set up on my forum which allows you to link to attachments in other posts:
BBCode usage:
[download={NUMBER}]{SIMPLETEXT2}[/download]
HTML replacement:
<br>
<dl class="attachbox">
<dd>
<dl class="file">
<dt><span class="imageset icon_topic_attach"></span> <a class="postlink" href="./download/file.php?id={NUMBER}">{SIMPLETEXT2}</a></dt>
</dl>
</dd>
</dl>
<br>
When Downloadbox is enabled, links made that way are dead. It's obscure, so no worries if there is no quick solution for this, but in case there is I thought I'd report it :)
Thanks!
