3.1.x Extensions Database 3.1 / 3.2Username Colour Changer
admin1
Re: Username Colour Changer
Post by admin1 »
When I install into 3.2.2 this is what I get.....
phpBB encountered an error building the container due to an installed extension. For this reason, all extensions have been temporarily disabled. Please try purging your forum cache. All extensions will automatically be re-enabled once the container error is resolved. If this error continues, please visit phpBB.com for support.
Exception: The file "/home/ngigesig/public_html/ext/dmzx/usernamecolourchanger/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @request").
#0 /home/ngigesig/public_html/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/ngigesig/...')
#1 /home/ngigesig/public_html/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/ngigesig/public_html/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/ngigesig/public_html/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/ngigesig/public_html/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/ngigesig/public_html/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/ngigesig/public_html/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/ngigesig/public_html/phpbb/di/container_builder.php(212): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/ngigesig/public_html/common.php(115): phpbb\di\container_builder->get_container()
#9 /home/ngigesig/public_html/adm/index.php(23): require('/home/ngigesig/...')
#10 {main}
kindly help
admin1 wrote: 05 Jan 2021, 17:46 When I install into 3.2.2 this is what I get.....
See viewtopic.php?p=7641#p7641
