Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 Pretty Topic
Wiroj
Re: Pretty Topic
Display Piority between LOCK and Announcement Topic
When "Announcement" Topic is Lock it's Displat "Lock"
I Think Announcement is first piority for display than Lock on topic.
leaf
Re: Pretty Topic
Hi, Thanks for the fabulous Mod.
I need some help.
How to set PT-BR in my Style (Subway) ?
Thanks.
I need some help.
Thanks.
RazKaziRo
Re: Pretty Topic
Will you Consider add the option to change the color by type and not use the same color for all topic status?
it will be helpful
it will be helpful
Re: Pretty Topic
RazKaziRo wrote:will you Consider add the option to change the color by type and not use the same color for all topic status?
it will be helpful
For now it will be not changed.
nelflucifer
Re: Pretty Topic
Good expansion that adds more prettiness to the themes I use the translation in Russian. Although the same old extension, but the main thing working.
English Forums
Fr0sTt
Re: Pretty Topic
Bulgarian language.
Re: Pretty Topic
eunaumtenhoid
Re: Pretty Topic
What is the extension and what is on the forum showing 3.1 or 3.2 before the titles of the topics?
eunaumtenhoid
Re: Pretty Topic
no no
I want to know what ext use to do the same effect in my forum.
Re: Pretty Topic
This one viewtopic.php?f=49&t=604
Re: Pretty Topic
He wants to know what ext places this in the topic title numbnuts.
Re: Pretty Topic
Ah see this viewtopic.php?f=51&t=976
