3.2 & 3.3 Extensions Database 3.2 / 3.3Posting Buttons
Null
Re: Posting Buttons
Post by Null »
Re: Posting Buttons
Yes.
1 shows the helpline the other dont.
1 is board wide the other not.
Null
Re: Posting Buttons
Post by Null »
Why 2 exactly equal exts?
Re: Posting Buttons
Not quite the same one was made and some one else made a little bit different version infact there is a few ext's out there that all do the same thing just made by different folks.
Joost
Re: Posting Buttons
Post by Joost »
How can i add a new module (Modcodes) for admins/mods only ? In the extension Advanced BBCode Box is it possible to change a permission to groups. :whistl:
Joost
Re: Posting Buttons
Post by Joost »
Joost wrote: 05 Feb 2017, 14:13 How can i add a new module (Modcodes) for admins/mods only ? In the extension Advanced BBCode Box is it possible to change a permission to groups. :whistl:
Up my post. :whistl:
Re: Posting Buttons
Joost wrote: 07 Feb 2017, 18:12
Is this related to Posting Buttons? or do you want to add it to Posting Buttons?
Joost
Re: Posting Buttons
Post by Joost »
I will add this to Posting Buttons. Is this possible in the next extension update? :eusa_dance:
Joost
Re: Posting Buttons
Post by Joost »
Up
Joost
Re: Posting Buttons
Post by Joost »
Up
Re: Posting Buttons
Need to check it.
mike
    Windows Vista Chrome
Re: Posting Buttons
Post by mike »
Hi everyone,
Would it be possible to make this great extension compatible with QuickReply Reloaded (version 2.0.0-beta1)?
Thanks in advance for your reply. :smile:
mike
Re: Posting Buttons
Post by mike »
mike wrote: 30 Jun 2017, 11:51 Hi everyone,
Is anyone there?
Re: Posting Buttons
You need to add an event template in postingbuttons and edit the postingbuttons.css
Copy the dmzx/postingbuttons/styles/all/template/event/posting_editor_buttons_after.html
to
dmzx/postingbuttons/styles/all/template/event/ext_quickreply_transform_text_buttons_after.htm
Then in the dmzx/postingbuttons/styles/all/theme/postingbuttons.css change that first class.
#format-buttons {
   display: none !important;
mike
Re: Posting Buttons
Post by mike »
Sniper_E wrote: 22 Aug 2017, 22:58 Copy the dmzx/postingbuttons/styles/all/template/event/posting_editor_buttons_after.html
to
Thanks for getting back to me. :smile:
However, I can only see these two files:
1) overall_header_head_append.html
2) posting_editor_buttons_before.html
Have also tried re-downloading a fresh download from the first page of this thread - and again, I don't see those files you mentioned.
