3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Reply to see content
kabauter
- New user
Re: Reply to see content
Hi ,
Using php board version 3.3.1
Using reply te see content version 1.02
set all the settings as i should be or maybe i forgot some .
Settings in acp main topic .
klik to see picture
did set the user permission right
for registered users
klik to see picture
for admin and moderators
klik to see picture
how ever as i want to post there is no reply to see content
klik to see picture
weird could not use the picture option to add the pictures so did it this way
could it be that i am using a dutch board ?
what am i doing wrong?
warm greetings
klik to see picture
klik to see picture
klik to see picture
klik to see picture
warm greetings
You just have to install it and set forum.kabauter wrote: 18 Dec 2020, 04:40 Hi ,
klik to see picture
klik to see picture
klik to see picture
klik to see picture
warm greetings
Remember default admin's group are able to see content, so try with other group.
- Banned
French translation for 1.0.3 version
Mitico
Re: Rispondere per visualizzare il contenuto
Hi, i would like to know for which version of phpbb it can be installed ? thanks..
medic
Hi can I use this extension to hide just extra links until reply without hiding posts ☺️
masterbiz_21
Hi, I have installed and activated on the forum but I don't see anything!
Then it's working properly. Now post a comment and see if the content shows.
masterbiz_21
Thanks for your answer, I tried everything but I don't see anything, set all the permissions, also created new forums, as a registered user but nothing I can't understand where the problem is!Sniper_E wrote: 20 May 2022, 08:26 Then it's working properly. Now post a comment and see if the content shows.
Alpha
French probleme double inscription
Bonjour, j'ai deux fois d'écriture sur mes postes comme ceci merci
ext/dmzx/imageupload/img-files/6317/e8a ... d6387b.png
Thats how its made top of box and bottom of box you could always delete the code in one of the events if you want it to show once but remember ppl are lazy and dont read whats on the screen.
Alpha
Salut non mais j'avais lu précis, mais c'est moi qui avais laissé un lien de trop par inadvertance merci
