3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ File Upload
Puchahawa
Re: File Upload
Post max size 3m local and master
Max execution is 120
Re: File Upload
Mine are on test:
max_execution_time 300
post_max_size 1048M
Can you change them and try again?
Puchahawa
Re: File Upload
Bingo! That got it working.
Thanks guys!
Thanks guys!
Puchahawa
Re: File Upload
Looked at my live board settings and set the local to the same and tested again to be sure. Was fine.
Puchahawa
Re: File Upload
Hopefully one last question.
I grabbed this snippet from image upload to add that bit about allowed extensions in the popup. I added it to the fileupload_body.php file. It's in the same place as the imageupload_body.php file and the label shows up in the popup but the extensions don't show. (see pic) Confused once again.
Tried it on my 3.1.10 and 3.2 boards same response.
<dd><label>{L_ALLOWED} {L_EXTENSION}{L_COLON}</label><!-- BEGIN allowed_extension --><!-- IF not allowed_extension.FIRST -->,<!-- ENDIF --> {allowed_extension.EXTENSION}<!-- END allowed_extension --></dd>
Re: File Upload
The $allowed_extensions is not in the file upload code yet.
Will be in next release.
Puchahawa
Re: File Upload
Ok
Are you going to add the acp changes like you did the image upload?
Re: File Upload
yes will add them alsoPuchahawa wrote: 27 Feb 2017, 23:09 ok![]()
BBBenj
Re: File Upload
Hello everybody,
In your next update, will it be possible to:
- suppress all forbidden caracters for uploaded files, such as space, +, and so on?
- change the directory for uploaded files?
Re: File Upload
Yes there will be an update soon.BBBenj wrote: 16 Mar 2017, 16:09 Hello everybody,
In your next update, will it be possible to:Thanks a lot, you've done here a really great job very valuable to me.
What directory (where) do you want to change it to?
BBBenj
Re: File Upload
Hi!
Great! I'm eager to see it!
Personnaly, I'd prefered a directory on the root of my forum, such as /files or /download, or even a directory which can be determined from the PCA or from inside your files (but an easier way than today!
