3.2.x Extensions Database 3.2 / 3.3Form Maker/Creator 3.2.x
Hippie459MN
Re: Form Maker/Creator 3.2.x
Post by Hippie459MN »
Honcho wrote: 21 Feb 2017, 20:10 I previously had this on 3.1.7
I dont mean to be OT here but where did you get this for 3.1.x? Would love to have it for 3.1.x Not yet ready to update to 3.2.x yet.
"I went outside once. The graphics sucked but the game play was ok."
Tarkonte
Post by Tarkonte »
Nice job, folks!
Now a question.
Could it be possible to integrate in a future release a couple of functionalities such as:
  • the capability to save in a new table (form_data) all the data filled in form
  • the capability to retrieve form data from DB instead of parsing the first post
  • the db design functions to integrate the form design
Unfortunately I'm not able to develop software in php, I've only a deep but 'ancient' knowledge of VB6, Clipper and C, so even if I would be glad to contribute in some ways, probably I could help you only with design and some sql definition.
Please let me know if I can help you in some way or if you could lead me in a temptative alternate extension development.
Thank you in advance.
Need to check on this, for making extensions see also https://github.com/phpbb-extensions/phpbb-ext-skeleton it will give default files for a start.
Tarkonte
Post by Tarkonte »
Here is attached the italian translation language (it) for the current release (1.0.0-dev).
unzip the file in the ext\dmzx\formcreator\language subfolder
In allegato la traduzione in italiano del pannello di controllo di Form Maker 1.0.0-dev.
Decomprimere lo zip all'interno della cartella ext\dmzx\formcreator\language.
@dmzx: please feel free to include the it language in the distribution package.
Tarkonte
Post by Tarkonte »
Hi dmzx!
Found an error I tried to fix myself.
PHP 7.0.16
Fatal error: Redefinition of parameter $form_id in C:\wamp64\www\phpBB3\ext\dmzx\formcreator\controller\admin_controller.php on line 332
PHP 7.0.10
PHP 5.6.25
No error!!!! It's running with flying colours!!!
I tried to fix it succesfully as follows:
Find
function build_preview($form_id, $form_id)
Replace with
function build_preview($form_id)
Checked against PHP 5.6.25, 7.0.10 & 7.0.16, in ACP creating and updating forms, and in new topic posting.
Found another error/strange behaviour:
When posting a new message with form fields, if the field is chosen from a selection box and it is not mandatory, the field box in the topic doesn't be populated with the relative value input.
The workaroud was to set all those fields as mandatory.
The same happens with checkboxes if the field values in options contain spaces (maybe!!!)
Thnk you for your support.
nickym0162
Post by nickym0162 »
I installed extension, after that i purge the cache, go to extensions menu open Form creator and i get blank screen ?
Tarkonte
Post by Tarkonte »
nickym0162 wrote: 04 Apr 2017, 15:36 I installed extension, after that i purge the cache, go to extensions menu open Form creator and i get blank screen ?
Probably you are using a default language different from english.
Copy subdir from ext/dmzx/formcreator/language/en to ext/dmzx/formcreator/language/[yourlanguage]
I solved in this way.
nickym0162
Already did but nothing
nickym0162
Hmm it works when i change my php to 5...
How can i fix it that it is working in PHP 7
Hippie459MN
Few problems with the extension. First it the text formatting. Some of the text is the default style text (Images in this example) when a form is created, some is a blocky ugly font/style that doesnt match any styles text.
Before:
After:
Looks much better!
I just edited the bbcode for the 'form'
Under the "HTML replacement" I changed the <pre>{TEXT}</pre> to just {TEXT}
I know its not really the best way to do it but it works and for some reason in the formcreator.css file, I removed the font-family line for .pre and even tried to change it to something else and it would not change the font, I even purged the cache and refreshed my browser with no luck so I did it with the bbcode.
Also, this does not play nicely with the Lighbox Extension (https://www.phpbb.com/customise/db/extension/lightbox/).
With the lightbox extension disabled:
With the Lightbox extension enabled:
It is resizing the image for the lightbox settings as the original image is 1920x1080 and I have the lightbox setting set to 700px and larger to resize.
Is there an easy way to fix this so the two dont conflict?
Thanks. :)
Tarkonte
Post by Tarkonte »
nickym0162 wrote: 04 Apr 2017, 16:28 Hmm it works when i change my php to 5...
Look at my previous post, in which I suggest a code modification.
It worked for me, either in PHP 5.6, 7.0.x and 7.1.x.
Hope this can help.
nickym0162
Thnx it works
PepeFJR
Post by PepeFJR »
Dmzx, why the Form button doesn't appear with the second post?
PepeFJR wrote: 07 Apr 2017, 22:55 Dmzx, why the Form button doesn't appear with the second post?
This is normal.
The button only show in first post and after that no more. (look also when you reply a post its gone)
PepeFJR
    Mac OS X iPad
Post by PepeFJR »
dmzx wrote: 08 Apr 2017, 07:25
This is normal.
Ok, thanks. But to have a Form only for the first post I think it's pretty useless...
[ Post made via iPad ] Image
