3.1 & 3.2 Extensions Database 3.1 / 3.2Social Buttons
Re: Social Buttons
Ok will add them in next release.
cov182004
Re: Social Buttons
Post by cov182004 »
dmzx wrote: 15 Jun 2016, 22:17 Ok will add them in next release.
thank you
taledus
Re: Social Buttons
Post by taledus »
I really like this mod.
I do not have RSS, but I do have a Google+ page for my group, so I am using it instead for the mean time until I can figure out how to modify things.
I also like the managements in ACP for Buttons menu. It's difficult to add predefined areas for every social media area someone could have. Is it possible to look into allowing the user to setup the social media links and images similar to how Buttons menu is? That may make it more flexible for people with different social media sites.
Anyways, again, I love this site and the work that is going into it. I have found a lot of very useful mods and information so far. Thanks for all the hard work!
Re: Social Buttons
Kevicar
Re: Social Buttons
Post by Kevicar »
Thank you very much for this new version.
Here is the file for the French translation - Social Buttons v1.0.1
fr.zip
:thumbup: :wave:
cov182004
Re: Social Buttons
Post by cov182004 »
Great update thank you Dmzx :tumbsyes:
phpbbexst
Re: Social Buttons
Post by phpbbexst »
You can insert HTML code only on the facebook button :question:
thank you
phpbbexst
Re: Social Buttons
Post by phpbbexst »
It is not possible?
It would be very helpful to me...I have to donate to get an answer?
Re: Social Buttons
Yes it is possible. You enter your Facebook page URL in that box... not your website URL. Then the Facebook link in your page will direct a member to your Facebook page.
If you want to change or add HTML codes to the button in your page... you will need to edit the templates in the extension file.
phpbbexst
Re: Social Buttons
Post by phpbbexst »
:tumbsyes: OK thank you very much
Patraix
Re: Social Buttons
Post by Patraix »
I don't see the options of modify links of social buttons for a open links in a new eyelash or page.
I use extension dmzx social buttons
Re: Social Buttons
Did you check ACP to modify the links?
Patraix
Re: Social Buttons
Post by Patraix »
dmzx wrote: 05 Jan 2017, 21:14 Did you check ACP to modify the links?
Yes, but I want open links in new page or eyelash
Re: Social Buttons
Patraix wrote: 05 Jan 2017, 22:53 Yes, but I want open links in new page or eyelash
open overall_header_searchbox_before.html
And replace all with:
<!-- IF SOCIALBUTTONS_ENABLE -->
<div class="top-social-home" id="top-social">
	<div id="top-social-icons">
		<!-- IF SOCIALBUTTONS_ENABLE_1 --><a href="{SOCIALBUTTONS_TEXT_FIELD_1}" target="_blank"><img alt="{L_SOCIALBUTTONS_RSS}" src="{BOARD_URL}ext/dmzx/socialbuttons/styles/prosilver/theme/images/rss-20.png"></a><!-- ENDIF -->
		<!-- IF SOCIALBUTTONS_ENABLE_2 --><a href="{SOCIALBUTTONS_TEXT_FIELD_2}" target="_blank"><img alt="{L_SOCIALBUTTONS_FACEBOOK}" src="{BOARD_URL}ext/dmzx/socialbuttons/styles/prosilver/theme/images/facebook-20.png"></a><!-- ENDIF -->
		<!-- IF SOCIALBUTTONS_ENABLE_3 --><a href="{SOCIALBUTTONS_TEXT_FIELD_3}" target="_blank"><img alt="{L_SOCIALBUTTONS_TWITTER}" src="{BOARD_URL}ext/dmzx/socialbuttons/styles/prosilver/theme/images/twitter-20.png"></a><!-- ENDIF -->
		<!-- IF SOCIALBUTTONS_ENABLE_4 --><a href="{SOCIALBUTTONS_TEXT_FIELD_4}" target="_blank"><img alt="{L_SOCIALBUTTONS_YOUTUBE}" src="{BOARD_URL}ext/dmzx/socialbuttons/styles/prosilver/theme/images/youtube.png"></a><!-- ENDIF -->
		<!-- IF SOCIALBUTTONS_ENABLE_5 --><a href="{SOCIALBUTTONS_TEXT_FIELD_5}" target="_blank"><img alt="{L_SOCIALBUTTONS_GOOGLEPLUS}" src="{BOARD_URL}ext/dmzx/socialbuttons/styles/prosilver/theme/images/googleplus.png"></a><!-- ENDIF -->
		<!-- IF SOCIALBUTTONS_ENABLE_6 --><a href="{SOCIALBUTTONS_TEXT_FIELD_6}" target="_blank"><img alt="{L_SOCIALBUTTONS_INSTAGRAM}" src="{BOARD_URL}ext/dmzx/socialbuttons/styles/prosilver/theme/images/instagram.png"></a><!-- ENDIF -->
		<!-- IF SOCIALBUTTONS_ENABLE_7 --><a href="{SOCIALBUTTONS_TEXT_FIELD_7}" target="_blank"><img alt="{L_SOCIALBUTTONS_SNAPCHAT}" src="{BOARD_URL}ext/dmzx/socialbuttons/styles/prosilver/theme/images/snapchat.png"></a><!-- ENDIF -->
	</div>
</div>
Clear cache, all links will open now in new page.
Patraix
Re: Social Buttons
Post by Patraix »
dmzx wrote: 05 Jan 2017, 23:00
	</div>
</div>
Thanks, now It opens new page :wink:
