3.2 & 3.3 Extensions Database 3.2 / 3.3Knuffel
Srad59
Re: Knuffel
Post by Srad59 »
Hello how to put the extension on MCHAT .
Thank you
Re: Knuffel
German language files - these files are for phpBB 3.1.x only!
The new language files are contained in the download packages of the newest versions since 1.0.2 for 3.2.x
Diese deutschen Sprachdateien sind nur für die veraltete Version 1.0.1 (phpBB 3.1.x). Für neuere Versionen sind die Sprachdateien ab v1.0.2 (für 3.2.x) künftig im Downloadpaket enthalten.
Re: Knuffel
Re: Knuffel
Perfekt- update after file replacement for 3.2.0 went fine.
Install on a fresh new 3.2.0 went fine, too.
Thank you! :buigen:
sile
Re: Knuffel
Post by sile »
Thank you so great :eusa_dance: :eusa_dance: :eusa_dance: :eusa_dance:
Re: Knuffel
kangeroe
Re: Knuffel
Post by kangeroe »
vito777
Re: Knuffel
Post by vito777 »
Thank you :tumbsyes:
U
utopia2016
Re: Knuffel
Post by utopia2016 »
:tumbsyes: :tumbsyes: :tumbsyes:
Thank
miri4ever
Re: Knuffel
Post by miri4ever »
If finished all rounds and wanted to spend points for the highscore list at end, if often happens people got logged out and all progress got lost after login again.
miri4ever
Re: Knuffel
Post by miri4ever »
I still got the problem, if spending points button pressed, i got logged out and everything is gone. It tthought it might the timeout cookie, but even if play fast as hell it also happen, and even on phpbb 3.3.0 this problem is still here.
    unknown Chrome
Re: Knuffel
miri4ever wrote: 29 May 2020, 22:03 I still got the problem, if spending points button pressed, i got logged out and everything is gone. It tthought it might the timeout cookie, but even if play fast as hell it also happen, and even on phpbb 3.3.0 this problem is still here.
did you set cookie right?
faroud
Re: Knuffel
Post by faroud »
HpBB Debug] PHP Notice: in file [ROOT]/ext/dmzx/knuffel/controller/main.php on line 228: Trying to access array offset on value of type bool
[phpBB Debug] PHP Notice: in file [ROOT]/ext/dmzx/knuffel/controller/main.php on line 229: Trying to access array offset on value of type bool
[phpBB Debug] PHP Notice: in file [ROOT]/ext/dmzx/knuffel/controller/main.php on line 230: Trying to access array offset on value of type bool
i only see a bugg when i want to play yahtzee (knuffel)
faroud
Re: Knuffel
Post by faroud »
Extension removed and re-uploaded
again that bug?
[phpBB Debug] PHP Notice: in file [ROOT] /ext/dmzx/knuffel/controller/main.php on line 228: Trying to access array offset on value of type bool
[phpBB Debug] PHP Notice: in file [ROOT] /ext/dmzx/knuffel/controller/main.php on line 229: Trying to access array offset on value of type bool
[phpBB Debug] PHP Notice: in file [ROOT] /ext/dmzx/knuffel/controller/main.php on line 230: Trying to access array offset on value of type bool
I think update to 3.3.3?
faroud
Re: Knuffel
Post by faroud »
:buigen:
