3.1 & 3.2 Extensions Database 3.1 / 3.2File Download
Re: File Download
romaamor wrote:
Look for `File Download` under the Disabled Extensions list, and click its `Enable` link.
I can not find. :sad:
did you place the files in ext/dmzx/filedownload/ ?
You had it working here:
romaamor wrote:How do I remove it?
romaamor
Re: File Download
Post by romaamor »
romaamor
Re: File Download
Post by romaamor »
Included. But the references in version 1.0.1 is still repeated.
Re: File Download
romaamor wrote:Included. But the references in version 1.0.1 is still repeated.
PM me link and test account of your board.
romaamor
Re: File Download
Post by romaamor »
® Комната отдыха ► Тест
artim
Re: File Download
Rename folder prosilver in ext\dmzx\filedownload\styles to all and clear the cache
romaamor
Re: File Download
Post by romaamor »
Did not help
I can give access FTP
Re: File Download
romaamor wrote:Did not help
Switch off ext/bb3mobi/inlineimgto test it.
romaamor
Re: File Download
Post by romaamor »
Now it works. Conflict extensions?
Re: File Download
romaamor wrote:Now it works. Conflict extensions?
Yes, can you zip that inlineimg here and I will take al look.
romaamor
Re: File Download
Post by romaamor »
inlineimg.zip
Re: File Download
Can you try it with this one and see is all is working
inlineimg.zip
romaamor
Re: File Download
Post by romaamor »
Thank you. Working.
Re: File Download
dmzx wrote:First post updated
I disabled extension, uploaded new one
But still have the problem that download shows 2 times.
Also cleared the cache..
=== EDIT ===
I did not read the previous messages.. sorry
It works now :eusa_dance:
Re: File Download
Im using the original version just renamed prosilver to all as i do with all ext :whistl:
