What version off this extension do you use?
3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Who Visited This Topic
- Banned
Re: Who Visited This Topic
Can you check the db table like below and post picture of it.
multigames
Hi dmzx,
here is my database screenshot, thanks
PostaL
Phpbb 3.3.10
FastCGI (Apache) php 8.2.0
Error when opening any topic
SQL ERROR [ mysqli ]
Expression #3 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'z123.w.counter_user' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055]
SQL
SELECT w.user_id, w.topic_id, w.counter_user, w.date, u.username, u.user_colour, u.user_id, u.user_avatar, u.user_avatar_type, u.user_avatar_height, u.user_avatar_width, u.user_type, SUM(w.counter_user) AS total FROM phpbb_whovisitedthistopic w, phpbb_users u WHERE w.topic_id = 7672 AND w.user_id = u.user_id GROUP BY w.user_id ORDER BY w.date DESC LIMIT 2
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 1023
CALL: trigger_error()
LINE: 202
FILE: [ROOT]/phpbb/db/driver/mysql_base.php
LINE: 45
LINE: 296
CALL: phpbb\db\driver\mysql_base->_sql_query_limit()
LINE: 337
CALL: phpbb\db\driver\driver->sql_query_limit()
FILE: [ROOT]/ext/dmzx/whovisitedthistopic/event/listener.php
LINE: 216
CALL: phpbb\db\driver\factory->sql_query_limit()
FILE: [ROOT]/vendor/symfony/event-dispatcher/EventDispatcher.php
LINE: 214
CALL: dmzx\whovisitedthistopic\event\listener->viewtopic_get_post_data()
LINE: 44
CALL: Symfony\Component\EventDispatcher\EventDispatcher->doDispatch()
FILE: [ROOT]/phpbb/event/dispatcher.php
LINE: 62
CALL: Symfony\Component\EventDispatcher\EventDispatcher->dispatch()
LINE: 46
CALL: phpbb\event\dispatcher->dispatch()
FILE: [ROOT]/viewtopic.php
LINE: 1320
CALL: phpbb\event\dispatcher->trigger_event()-
is your ONLY_FULL_GROUP_BY on in MySQL?PostaL wrote: 28 Feb 2023, 03:53 phpbb 3.3.10
Error when opening any topicCode: Select all
SQL ERROR [ mysqli ] Expression #3 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'z123.w.counter_user' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055] SQL SELECT w.user_id, w.topic_id, w.counter_user, w.date, u.username, u.user_colour, u.user_id, u.user_avatar, u.user_avatar_type, u.user_avatar_height, u.user_avatar_width, u.user_type, SUM(w.counter_user) AS total FROM phpbb_whovisitedthistopic w, phpbb_users u WHERE w.topic_id = 7672 AND w.user_id = u.user_id GROUP BY w.user_id ORDER BY w.date DESC LIMIT 2 BACKTRACE FILE: (not given by php) LINE: (not given by php) CALL: msg_handler() FILE: [ROOT]/phpbb/db/driver/driver.php LINE: 1023 CALL: trigger_error() FILE: [ROOT]/phpbb/db/driver/mysqli.php LINE: 202 CALL: phpbb\db\driver\driver->sql_error() FILE: [ROOT]/phpbb/db/driver/mysql_base.php LINE: 45 CALL: phpbb\db\driver\mysqli->sql_query() FILE: [ROOT]/phpbb/db/driver/driver.php LINE: 296 CALL: phpbb\db\driver\mysql_base->_sql_query_limit() FILE: [ROOT]/phpbb/db/driver/factory.php LINE: 337 CALL: phpbb\db\driver\driver->sql_query_limit() FILE: [ROOT]/ext/dmzx/whovisitedthistopic/event/listener.php LINE: 216 CALL: phpbb\db\driver\factory->sql_query_limit() FILE: [ROOT]/vendor/symfony/event-dispatcher/EventDispatcher.php LINE: 214 CALL: dmzx\whovisitedthistopic\event\listener->viewtopic_get_post_data() FILE: [ROOT]/vendor/symfony/event-dispatcher/EventDispatcher.php LINE: 44 CALL: Symfony\Component\EventDispatcher\EventDispatcher->doDispatch() FILE: [ROOT]/phpbb/event/dispatcher.php LINE: 62 CALL: Symfony\Component\EventDispatcher\EventDispatcher->dispatch() FILE: [ROOT]/phpbb/event/dispatcher.php LINE: 46 CALL: phpbb\event\dispatcher->dispatch() FILE: [ROOT]/viewtopic.php LINE: 1320 CALL: phpbb\event\dispatcher->trigger_event()
Check it like this:
SHOW VARIABLES LIKE 'sql_mode';
And post the output here.
PostaL
dmzx wrote: 01 Mar 2023, 10:33 is your ONLY_FULL_GROUP_BY on in MySQL?
Check it like this:
use these 2 commands:
SET SESSION sql_mode = 'STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION';
SET GLOBAL sql_mode = 'STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION';
then check:
And look if ONLY_FULL_GROUP_BY is gone, then test extension.
Peralta
- Donator
Hello dmzx, there is a syntax error in a language variable:
open ./ext/dmzx/whovisitedthistopic/adm/style/acp_whovisitedthistopic.html
Should be:
Thanks for the update
<input class="button1" type="submit" id="submit" name="submit" value="{{ lang('submit') }}" />Code: Select all
<input class="button1" type="submit" id="submit" name="submit" value="{{ lang('SUBMIT') }}" />I speak spanish. Sorry for my bad english.
Thanks will correctPeralta wrote: 01 Mar 2023, 17:09 Hello dmzx, there is a syntax error in a language variable:
open ./ext/dmzx/whovisitedthistopic/adm/style/acp_whovisitedthistopic.htmlShould be:Code: Select all
<input class="button1" type="submit" id="submit" name="submit" value="{{ lang('submit') }}" />Thanks for the updateCode: Select all
<input class="button1" type="submit" id="submit" name="submit" value="{{ lang('SUBMIT') }}" />![]()
PostaL
SET SESSION sql_mode = 'STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION';dmzx wrote: 01 Mar 2023, 16:24 use these 2 commands:
then check:
- Banned
Download the french language pack for 1.0.9 version ici
Check if you can see where you can disable ONLY_FULL_GROUP_BY I dont know is your provider must do it.PostaL wrote: 01 Mar 2023, 20:12SET SESSION sql_mode = 'STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION';dmzx wrote: 01 Mar 2023, 16:24 use these 2 commands:
then check:
