Extensions Database 3.2 / 3.3 ⇒ 3.2 & 3.3 File Upload
3.2.x & 3.3.x
1 given 2
Re: File Upload
martin wrote: 07 Jul 2018, 16:07 what does it say in this image Image
Enable file upload - YES
In php.ini file max size is 2MB
so? :eyes2:
1 given 2
Re: File Upload
Mate you cant be that stupid can you ?
it says "The maximum size your php.ini allows is 2MB"
That means your host only allows 2MB file size uploads.
15 given 2
Re: File Upload
:yikes:
Re: File Upload
martin wrote: 07 Jul 2018, 16:15 Mate you cant be that stupid can you ?
:rolling: :rolling:
lopoto
0 given 2
    Mac OS X iPhone
Re: File Upload
Post by lopoto »
:lol:
1 given 2
Re: File Upload
Why when i upload a file with choosen name then tryed to download not appear on my screen with original name? (i choose)
u upload this file
File Upload by тест
on my board it called test as u can see on here
but when i downloaded thro my test board it with other name why? :eyes2: :roll: :question:
1 given 2
Re: File Upload
It's renamed incase you have another upload with the same name just like windows does martin.zip martin(1).zip also stops users guessing the name.
1 given 2
Re: File Upload
martin wrote: 01 Aug 2018, 00:03 It's renamed incase you have another upload with the same name just like windows does martin.zip martin(1).zip also stops users guessing the name.
look at your PM :roll:
killfrenzy
Re: File Upload
Post by killfrenzy »
ivailo95 wrote: 31 Jul 2018, 23:19 why when i upload a file with choosen name then tryed to download not appear on my screen with original name? (i choose)
u upload this file
File Upload by тест
Can I use this because I want to use the fileupload with the same filename instead. thanks
Visit my blog http://androidcribs.com Androidcribs.comAndroidcribs Image
1 given 2
Re: File Upload
Um yea,but this is not edited, it's just test file
15 given 2
Re: File Upload
15 given 2
Re: File Upload
vince
    Mac OS X iPhone
Re: File Upload
Post by vince »
Can the folder where the dl goes be changed to a diff folder
Barrybrennan
    Windows 10 Edge
Re: File Upload
Post by Barrybrennan »
Thank u :)
BarTender
Re: File Upload
Post by BarTender »
Bonjour j'ai installer " Téléchargement de fichiers" mais il me dise " Le répertoire temporaire est introuvable ou est en lecture seule." j'ai essayer mais je ne comprend pas quoi faire :wall:
