Thank you, now it works great
3.2 & 3.3 Extensions Database 3.1 / 3.2 ⇒ Mobile Device
all4phone
- Donator
Re: Mobile Device
all4phone
- Donator
Re: Mobile Device
Polish translation v 1.0.4
Btw,
'MOBILE_CLEAR_LOGS' => 'Clear logs', appears twice:
language/en/common.php - lines 50 and 59
language/pl/common.php - lines 51 and 60 (second line commented out by me, correct please if I'm wrong)
Btw,
Kinsman
Re: Mobile Device
I just installed 1.04 and weirdly cannot seem to set permissions for it?
I assume this is the step I'm missing, but cannot find them anywhere? Yes it's on, and yes I cleared cache.Set the permissions for your other groups and users in the ACP / Permissions
Re: Mobile Device
No in the acp you can enable welcome message for users and enable welcome message for guests along with allow mobile header image.
That's about it. A registered user can go into their user control panel and disable the welcome message if they don't want to see it.
What kind of permissions do you think needs to be set? We did not see that was needed.
Thank you all4phone, I'll look into that language file edits.
Kinsman
Re: Mobile Device
Oh ok, I got that from your post a few pages back, so I guess that explains why no permissions. Could you point me to where in the UCP those settings are, as I cannot find them either.
So far I cannot find any evidence of the mod besides the admin settings page.
Kinsman
Re: Mobile Device
so I guess that explains why no permissions. Could you point me to where in the UCP those settings are, as I cannot find them either.Sniper_E wrote: 20 Dec 2015, 21:17 To install the newest version you should take these steps:
- Disable the extension.
- Deleta data from the extension.
- Delete the files from your server.
- Copy the new version files to your server.
- Enable the extension.
- Choose your settings for the extension in the ACP / Extensions / Mobile Device
- Set the permissions for your other groups and users in the ACP / Permissions
Kinsman
Re: Mobile Device
Sweet, it started working!
http://www.junglewraiths.net/viewtopic.php?f=3&t=4757
I'm trying to add my phone, but obviously made a mistake somewheres and the entire site became a white page.
Mozilla/5.0 (Windows Phone 10.0; Android 6.0.1; NOKIA; Lumia 830) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.79 Mobile Safari/537.36 Edg
and this is our 640xl
Mozilla/5.0 (Mobile; Windows Phone 8.1; Android 4.0; ARM; Trident/7.0; Touch; rv:11.0; IEMobile/11.0; Microsoft; Lumia 640 XL LTE) like iPhone OS 7_0
I think the bit I'm struggling with is adding "Windows Phone 10.0" and "Windows Phone 8.1" or do I not need those?
Kinsman
Re: Mobile Device
Getting closer, but the browser type is a bit weird. The 830 has none, and the 640 is being identified as Iphone even though this code is at the very top.
Weirdly if I do not identify them the windows smartphone browser icon is fine.
case (preg_match('/(iris|3g_t|windows ce|windows Phone|windows Phone 10.0|windows Phone 8.1|opera mobi|windows ce; smartphone;|windows ce; iemobile)/i',$user_agent));
if (preg_match('/Lumia 830/i',$user_agent))
$status = 'Lumia 830';
$mobile_browser = $windows;
elseif (preg_match('/Lumia 640 XL LTE/i',$user_agent))
$status = 'Lumia 640XL';
else
$status = 'Windows Phone';
break; -
Kinsman
Re: Mobile Device
How does one get permission to view mobile logs? I finally found the link after removing the requirement to see it, but now do not have permission to view?
Re: Mobile Device
That permission is set on install with the migrations/mobiledevice_data.php
Only Admins can clear the mobile logs and view the logs. I don't think we made a switch for that.
// Add permissions
array('permission.add', array('u_mobile_logs_view')),
array('permission.add', array('u_mobile_logs_clear')),
// Set permissions
array('permission.permission_set', array('ADMINISTRATORS', 'u_mobile_logs_view', 'group')),
array('permission.permission_set', array('ADMINISTRATORS', 'u_mobile_logs_clear', 'group')),-
Kinsman
Re: Mobile Device
Mmm I'm. A founder, I figured that would have been enough, will add myself to admin and try again
[ Post made via Android ]
Kinsman
Re: Mobile Device
Yep spoton, only Admins see it.
Would it be difficult to add another browser type? A lot of our users have tapatalk.
Mozilla/5.0 Firefox/3.5.6 Tapatalk/1549
also if anyone want s a windows 10 icon here you go.
Re: Mobile Device
Is taptalk off the net? What would you call that? windows? android? Pick one of the mobile_device_detect listed.
Then add a Taptalk.png image to the images/ directory. (32px height)
case (preg_match('/taptalk/i',$user_agent));
$status = 'Taptalk';
break;
Kinsman
Re: Mobile Device
Tapatalk is an app that works on any device.
https://www.tapatalk.com/
Hence why it would need to be added as another browser type, not a device.
Update: wait, I'm a idiot, if I put that first then it will tell they are using tapatalk, not their device I reckon, will give it a try.
Mmm, but then all tapatalk users become windows browser? Maybe I could add it before each type? say before android starts, etc etc?
Re: Mobile Device
I thought so. I know what Taptalk is. Use that code, grab that image and test it out.
