3.1.x Extensions Database 3.1 / 3.2 ⇒ Ultimate Points Extension
killfrenzy
Re: Ultimate Points Extension
I just wonder if possible to have points in every game they won like hangman, jack en poy. etc. hehe
Visit my blog http://androidcribs.com Androidcribs.com
Matrixer
dmzx wrote: 03 Jun 2016, 11:53repedeGP wrote: 03 Jun 2016, 04:48 Hey there! I've been using this extension on a forum I run for a few months, now. Absolutely love it!
I had a problem presented to me, however. When our users try to Donate the currency to one-another, it simply refreshes their intended recipient's profile page. I've had a few different users attempt it, on different browsers, and they're all experiencing the same issue. I, however, can donate just fine.
I've tried hunting around in the settings, and found that donations is properly enabled. I've tried looking through permissions, but didn't find anything (for group permissions at least) aside from making users Pay to post, and the like.
It likely matters, but we're still running 1.1.1. Yeeeaaah, a little behind. oops.
Will updating fix this? Is this a common issue?
Sorry if the question is a dumb one, I've had a long day at work and can't find the answer on my own ;_;Open ext\dmzx\ultimatepoints\event\listener.phpFind This may be a partial find and not the whole lineCode: Select all
'U_POINTS_DONATE' => ($this->auth->acl_get('a_') || $this->auth->acl_get('m_chg_points')) ? $this->helper->route('dmzx_ultimatepoints_controller', array('mode' => 'transfer', 'i' => $user_id, 'adm_points' => '1')) : '',Will be fixed in next releaseReplace with Replace the preceding lines with the followingCode: Select all
'U_POINTS_DONATE' => ($this->auth->acl_get('u_use_points')) ? $this->helper->route('dmzx_ultimatepoints_controller', array('mode' => 'transfer', 'i' => $user_id, 'adm_points' => '1')) : '',![]()
Many Thanks for this solution - when I found out last night that the donate button doesn't work for users I almost wanted to get a day job back - hahahaha
Thread
How to fix?
Everytime i try to submit a setting change - It logs me off.
camplife
You should be able to set that in Group Permissions.
killfrenzy
This one of my favorite extensions. I didn't noticed that my Ultimate Extension is outdated 1.1.2 and need to update to the latest 1.1.5. Do I need to backup in database to prevent lost of points? Sir what is the proper way to update this extension without losing the data and points of the members?
x8BiTw0LFx
Yes, don't install the migration folder.killfrenzy wrote: 12 Sep 2016, 17:03 This one of my favorite extensions. I didn't noticed that my Ultimate Extension is outdated 1.1.2 and need to update to the latest 1.1.5. Do I need to backup in database to prevent lost of points? Sir what is the proper way to update this extension without losing the data and points of the members?
x8BiTw0LFx
Nope :(
camplife
I think so...under advanced permissions, the Ultimate Points tab.x8BiTw0LFx wrote: 12 Sep 2016, 23:25Nope :(
x8BiTw0LFx
Nope - doesn't work :(camplife wrote: 13 Sep 2016, 00:08I think so...under advanced permissions, the Ultimate Points tab.x8BiTw0LFx wrote: 12 Sep 2016, 23:25Nope :(
camplife
Do you have this??x8BiTw0LFx wrote: 14 Sep 2016, 23:37Nope - doesn't work :(camplife wrote: 13 Sep 2016, 00:08I think so...under advanced permissions, the Ultimate Points tab.x8BiTw0LFx wrote: 12 Sep 2016, 23:25Nope :(
x8BiTw0LFx
Yes, and everything is set to no, but still receiving points :(
camplife
Are they a member of another group that IS allowed to use UP?x8BiTw0LFx wrote: 15 Sep 2016, 15:06Yes, and everything is set to no, but still receiving points :(
ameners
Super add-on! :)
Polish translation please
camplife
Instead of "No", try "Never". I think "No" can be over-ridden by other settings whereas "Never" cannot. (I think that's how it works)x8BiTw0LFx wrote: 15 Sep 2016, 15:06Yes, and everything is set to no, but still receiving points :(
