Donation Extension with auto groups 1.2.5 is out! Due to server shutdown for keyserver new keys must be made for Who is Where and Donation extension, you need to update Who is Where and Donation extension.
To make a key see
Add Key
3.2.x Extensions DatabaseMemberlist Avatar 3.2.x
<span class="qte-attr qte_32-qte">3.2.x</span>
Referrals: 48
Post by dmzx » 01 Mar 2016 13:09
Extension Name: Memberlist Avatar 3.2.x
Shows user avatars on memberlist.
Memberlist Avatar 3.2.x v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `memberlistavatar`.
  4. Copy the `memberlistavatar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/memberlistavatar/composer.json
  6. Look for `Memberlist Avatar` under the Disabled Extensions list, and click its `Enable` link.
This topic has 6 replies
