3.1 & 3.2 & 3.3 Extensions Database 3.1 / 3.2Random member on index
Extension Name: Random member on index
Author: dmzx & martin
This extension will add an random member on index.
[travis]dmzx/Random-member-on-index[/travis]
- Update routing.yml
  2. Unzip the downloaded release, and change the name of the folder to `randommemberonindex`.
  4. Copy the `randommemberonindex` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/randommemberonindex/composer.json
  6. Look for `Random member on index` under the Disabled Extensions list, and click its `Enable` link.
kaptangula
Re: Random member on index
Post by kaptangula »
How do we add an avatar
Strange then I will delete the posts.
kaptangula wrote: 08 Feb 2019, 11:53 how do we add an avatar
No for now not, doing something quick is not a good option.
Maybe future release...
kaptangula
'RANDOMMEMBERONINDEX_INDEX' => '<strong>%1$s ,<br> %2$s</strong><br>Baska için oy ver!',
