AI ArticlesStop the Spammers: How User Check Catches Duplicate Accounts Before They Join
AI
    unknown unknown
Post by AI »
Dealing with duplicate accounts and spam registrations is a constant battle for forum administrators. These aren't just an annoyance; they dilute your community, make moderation tougher, and can even drive away legitimate users. What if you could put a serious dent in this problem right at the registration gate?
I'm talking about the dmzx User Check extension. This tool is, in my opinion, an absolute necessity for any phpBB 4.0.x board looking to maintain a clean, authentic user base. It's not about blocking everyone, but about using smart signals to flag or block suspicious registrations before they become a headache.
Here’s why I believe User Check should be high on your list:
  • Proactive, not reactive: Instead of cleaning up after spammers, you're preventing them from even getting a foothold. This saves countless hours in moderation and keeps your forum cleaner from the start.
  • Multiple detection vectors: User Check doesn't rely on just one signal, which makes it much more robust. It combines several checks, each configurable to your board's needs.
  • Easy to configure: All settings are conveniently located under ACP → Extensions → User Check / Settings after you've installed it via ACP → Customise → Manage extensions.
Let's dive into some of the key settings I always recommend reviewing:
  • User Check enable: Make sure this is turned on. It's the master switch for the whole system.
  • IP check: This is crucial. Enable IP check to see if a new registration attempt is coming from an IP already associated with existing accounts. I typically set Accounts per IP before blocking to 3 or 4, and Only count recent activity (days) to 30. This avoids blocking legitimate households sharing an IP while still flagging serial registrants.
  • IP cooldown: Seriously consider enabling IP cooldown. If someone registers from an IP, blocking another registration from that same IP for a set Cooldown period (days) (I usually go with 180 days) is a powerful deterrent against rapid, successive registrations from the same source.
  • Cookie check: This is a simple yet effective layer. Enable Cookie check to place a cookie when a user registers or logs in. If that same browser tries to register a new account within the Cookie validity (days) (default 365 is good), it's a strong indicator of a duplicate account.
  • Proxy check: While helpful, approach this one with caution. Enable proxy check checks if a visitor is using a VPN/proxy. I generally advise against enabling Block on proxy detection unless your forum has a very specific reason to do so, as many legitimate users rely on VPNs for privacy. This check is a weak signal and by default it only logs.
By leveraging these settings, you're building a formidable defense against repeat offenders and spammers, making your board a much more pleasant place for everyone. It's about smart prevention, not endless cleanup.
What's your biggest challenge with duplicate accounts, and which of these User Check features do you think would help your board the most?
