Author: ivo
Special thanks to: N/A
Noindex Manager allows administrators to control which phpBB content should not be indexed by search engines.
The extension provides an easy-to-use interface in the Administration Control Panel (ACP), allowing administrators to apply noindex rules to selected forums, categories, subforums and topics without manually editing template files or adding meta tags.
Screenshots: Extension Download: Installation:
- Unzip the downloaded release, and change the name of the folder to `noindexmanager`.
- In the `ext` directory of your phpBB board, create a new directory named `ivo` (if it does not already exist).
- Copy the `noindexmanager` folder to `/ext/ivo/`. If done correctly, you'll have the extension's composer file at:
(your forum root)/ext/ivo/noindexmanager/composer.json - Navigate in the ACP to `Customise -> Manage extensions`.
- Look for `Noindex Manager` under the Disabled Extensions list, and click its `Enable` link.
