Author: ivo
Special thanks to: N/A
Drag & Drop Forum Manager allows administrators to easily reorganize phpBB categories, forums, links and complete subforum branches using drag and drop.
Items can be moved before, inside or after another forum, or returned to the main level. Changes are only applied after pressing the save button. The extension also includes server-side structure validation, database transactions and rollback protection.
Screenshots: Extension Download: Installation:
- Unzip the downloaded release, and make sure the extension folder is named `forumdragdrop`.
- In the `ext` directory of your phpBB board, create a new directory named `ivo` if it does not already exist.
- Copy the `forumdragdrop` folder to `/ext/ivo/`. If done correctly, you'll have the main extension file at:
(your forum root)/ext/ivo/forumdragdrop/composer.json - Navigate in the ACP to `Customise -> Manage extensions`.
- Look for `Drag & Drop Forum Manager` under the Disabled Extensions list, and click its `Enable` link.
