3.2 & 3.3 Extensions Database 3.2 / 3.3Admin Customiser
Admin Customiser
Extension Name: Admin Customiser
Author: ivo
Special thanks to: N/A
Admin Customiser allows administrators to customise the appearance of the phpBB Administration Control Panel (ACP). The extension provides options to change the main ACP colour, set a custom background image, and personalise the overall appearance of the administration panel directly from the ACP.
acpcustomizer.zip
  2. Unzip the downloaded release and change the name of the folder to `admincustomiser`.
  3. In the `ext` directory of your phpBB board, create a new directory named `ivo` if it does not already exist.
  4. Copy the `admincustomiser` folder to `/ext/ivo/`. If done correctly, the extension's `composer.json` file will be located at:
    (your forum root)/ext/ivo/admincustomiser/composer.json
  5. Navigate in the ACP to `Customise -> Manage extensions`.
  6. Look for `Admin Customiser` under the Disabled Extensions list and click its `Enable` link.
