3.1 & 3.2 Extensions Database 3.1 / 3.2Topic Author
iorG19
Re: Topic Author
Post by iorG19 »
I don't see it in extension tab.
Re: Topic Author
It has no settings thats why.
iorG19
Re: Topic Author
Post by iorG19 »
martin wrote: 18 Mar 2017, 17:04 It has no settings thats why.
So how can i see it in this cute apareance like here ? ( With color background )
Re: Topic Author
I stand corrected yes it does show under the ext tab and have settings (the first version did not)
iorG19
Re: Topic Author
Post by iorG19 »
I just download the current ( 1.0.4 ) and i can't extract files.
Re: Topic Author
Try this one
Re: Topic Author
martin wrote: 18 Mar 2017, 17:38try this one
Changed zip in first post.
Re: Topic Author
:thumbup: Files was fresh from my acp if you used them.
John Mates
Re: Topic Author
Post by John Mates »
Great ext :mml: but could I suggest that Topic Authors who are Guests are ignored from this Ext? otherwise every time a Guest starts a thread then every guest in the Thread (with all their different names) is shown as the Topic Author :oops: which looks a little lame
Re: Topic Author
John Mates wrote: 29 Mar 2017, 21:20 great ext :mml: but could I suggest that Topic Authors who are Guests are ignored from this Ext? otherwise every time a Guest starts a thread then every guest in the Thread (with all their different names) is shown as the Topic Author :oops: which looks a little lame
Will look into this!
Mommike
Re: Topic Author
Post by Mommike »
Nice extension!
How can I enter little bit longer text to this label? Right now seems 10 characters is the limit.
Re: Topic Author
Mommike wrote: 02 Apr 2017, 08:58 Nice extension!
check the maxlength in acp_topicauthor_config.html
Line:
<input name="topicauthor_text_field" type="text" id="topicauthor_text_field" class="inputbox autowidth" value="{TOPICAUTHOR_TEXT_FIELD}" maxlength="10" />
Make 10 a other value and clear cache. ;)
Mommike
Re: Topic Author
Post by Mommike »
Thank worked fine!
One more question. It capitalize every word. How do modify that it showing exactly this way, as I write inside ACP.
Re: Topic Author
Mommike wrote: 02 Apr 2017, 11:01 Thank worked fine!
This should not be, what did you add in ACP?
Mommike
Re: Topic Author
Post by Mommike »
dmzx wrote: 02 Apr 2017, 11:08
Sorry, my bad. It is under the extensions tab, Topic author - Adjust topic author text. How to modify that it showing the text exactly this way, as I write inside this field.
