Extensions Database 3.2 / 3.3 / 4.0 ⇒ 3.2 & 3.3 Download limit
3.2 & 3.3 & 4.0
Re: Download limit
I know nothing about this ext at all but I just looked in the v102 migration...
		$downloadlimit_exts = [
			'7z','ace','bz2','gtar','gz','rar','tar','tgz','torrent','zip'
There is no 'nzb' listed there. Does that mean it's not counting the .nzb downloads?
Just a thought...
clight77 wrote: 22 Dec 2019, 15:17Also waiting for Sniper_E to reply to see if he was reset.
Sorry buddy I forgot I was testing. Did I ever get back to you on that?
19 given 2
Re: Download limit
clight77 wrote: 24 Apr 2023, 04:53 Don't seem to work at all now for nobody. :(
Martin now thinks it is an extension conflict... We are trying to find the one..
Under test now, did install on fresh forum.
1 given 2
Re: Download limit
99% sure it's ext conflict.
Fails to work on my site but works perfect on test site with ext's off.
19 given 2
Re: Download limit
martin wrote: 25 Apr 2023, 01:22 99% sure it's ext conflict.
All test untill now on my test board work fine, will do some small code update but cannot recall the issues there.
Think martin is not right... :whistl:
But will do some more checks.
1 given 2
Re: Download limit
Nope i was wrong but did find the issue :yikes:
If you hit the limit and go sit on index for the set time the ext works perfect.
If you hit the limit and go surf the forum or forums that have a download in the timer restarts over and over each topic you visit resets the timer from start.
19 given 2
Re: Download limit
martin wrote: 25 Apr 2023, 14:00 Nope i was wrong but did find the issue :yikes:
will check....
19 given 2
Re: Download limit
dmzx wrote: 25 Apr 2023, 16:02
will check....
Did check the time value if download is done but that is correct.
Do find time() of server though, will look into this.
Re: Download limit
Hey DM
What is happening on my site seems to be....
If I set it for 1 hour it takes 2 hours to reset.
If I set it for 2 hours it takes 4 hours to reset.
If I set it for 3 hours it takes 6 hours to reset.
ETC ...
Just info :)
19 given 2
Re: Download limit
clight77 wrote: 27 Apr 2023, 07:56 Hey DM
ETC ...
Just info :)
There is a thing going on with server time()
I have normally +1 gmt but if I set it lower then 3 hours the cron is in the past, so need to check from there. Did update time on server to check.
Re: Download limit
Martin did update my server time in the files.
lol
Re: Download limit
Post by lol »
I just read the full thread, this extension sounds very promising :) thanks for it. Is it working to download any attachement in post, that are allowed in ACP ?
lol
Re: Download limit
Post by lol »
Could it be possible to combine it with ultimate point extension to allow users with a certains amount of points to increase the limit ?
i think about a system where leeschers are limited but posters can earn points to download more than the limit ?
19 given 2
Re: Download limit
lol wrote: 11 Dec 2024, 11:59 Could it be possible to combine it with ultimate point extension to allow users with a certains amount of points to increase the limit ?
Will look into integration options in this extension. For now updating other extensions is more prio but will take a look into this.
lol
Re: Download limit
Post by lol »
super, there is no urgency, could be nice for my project, i can explain more my idea, just let me know where should i do it (question forum ?) to do it at the right place :wink:
19 given 2
Re: Download limit
lol wrote: 11 Dec 2024, 15:53 :thumbup:
See this section ideas
