Extensions Database 3.2 / 3.3 / 4.0 ⇒ 3.2 & 3.3 Download limit
3.2 & 3.3 & 4.0
Fast_Eddie
Re: Download limit
Post by Fast_Eddie »
Yes, :) :tumbsyes: :buigen:
:beers: Retirement 2024!
Fast_Eddie
Re: Download limit
Set time period for prune/delete users
In the d/l limit ACP does this option really delete users? I think it's supposed to re-set the timer for more downloads ?
1 given 2
Re: Download limit
There is no option to delete user's it's just a download limit with a cron.
I think your find thats a lang that some one forgot to change lol no it dont delete thats the time for the cron to run.
Fast_Eddie
Re: Download limit
Thats kind of what i thought but wanted to make sure before i enabled it.....the way it reads (in the acp) looks like it will delete/prune
19 given 2
Re: Download limit
Will check on that lang part. :thumbup:
Re: Download limit
19 given 2
Re: Download limit
clight77 wrote: 05 Aug 2019, 15:48
Yes looks ok to me.
Re: Download limit
dmzx wrote: 05 Aug 2019, 18:02
Yes looks ok to me.
There was a bit of a typo in the 1st one.. :(
New
19 given 2
Re: Download limit
Martin did it :whistl: he always does... :rolling:
Re: Download limit
dmzx wrote: 05 Aug 2019, 21:24 Martin did it :whistl: he always does... :rolling:
No, it was me.. lol
1 given 2
Re: Download limit
My 1.0.2 has prune users :rolling: guess im using the one from the test section.
Hmm just downloaded public version and i see this in lang
'DOWNLOADLIMIT_TIME_VALUE'					=> 'Set time period for prune/delete users',
'DOWNLOADLIMIT_TIME_VALUE_EXPLAIN'			=> 'This option will set the prune/delete timer. Default is 24 hours.',
Re: Download limit
martin wrote: 06 Aug 2019, 13:49 My 1.0.2 has prune users :rolling: guess im using the one from the test section.
Hmm just downloaded publiv version and i see this in lang
LOL I changed the language in mine :)
Re: Download limit
I think I may have found a small issue.
I have a Supporters group (once you donate you go there) and are exempt from the download limit, but if a user has downloaded their limit for the set 12 hour period and they decide to donate to get unlimited downloads it seems they have to wait until the 12 hours is up.
Can that be sorted ?
THX.
19 given 2
Re: Download limit
Ok will check this out when back from holiday.
Have to intergrate donation extension or do cron check on groups.
Re: Download limit
dmzx wrote: 19 Aug 2019, 09:32 Ok will check this out when back from holiday.
Happy holidays :)
No rush,just thought I would mention it :)
THX
